Google Pixel 9 Pro Fold
limmk
Is it really the best cam on a foldable??
Among all the foldables, DxOMark even rank it #1, above Galaxy Z Fold 6 and OG Pixel Fold. but if compare to normal Pixel phone, low-light and sensor performance still lose a bit. OnePlus Open or Vivo X Fold 3 Pro maybe got better hardware, somemore price maybe same or cheaper, especially for camera stuff
hellhole
once again... the phone sim disappear when unfolded...
when folded.. it is fine.. once unfold... the network not detected and no sim is detected...
somehow... it seems to occur after an update!! hahaha.. not sure it is software or hardware related...
sigh... going to back up every f thing and send it in...
btw... anyone experience that when unfolded... it seems to take a few sec before the screen comes on... searches says that one of the app was causing this... something ' cursor' ,, but i do not have that app... seems to be apps that uses the float over screen option
hawkerhero
Hardware related. This is one of the most common faults. Go make appointment CTDI Google at Aperia Mall. They'll fix it in a few hours be replacing the entire frame/screen. You basically you get a new phone. :) You'll notice the hinge will be better (less noticeable screw marks).
Don't need to back up, it has a recovery mode.
If you don't fix it, it'll get worse rapidly.
hellhole
yeah... today the whole front screen screw up... !!!
i need to back up .. its okay...
aigh...
hawkerhero
aigh...
Yup... then it'll stop charging too eventually unless you unfold it. Then when charging, touch screen doesn't work.
Don't try to restart the phone btw.
Time to get Pixel 10 Pro Fold. :) No more hinge.
hellhole
i thought about it... but this 9 seems to work very well.. ahhaah... till yesterday!
i think i will go for 11.... its still under warranty lah!!! lets go!
GeSteSoh
Anyone experience sudden battery percentage drop, after leaving it overnight? Mine drops to around 50% overnight the next morning, after leaving it from 80+% the night before.
GeSteSoh
Smelly tortise‼️ It was the Google Home app that was causing all that abnormal battery drain, all's fine now afetr uninstalling:confused:o_O:censored:
GeSteSoh
Good thing you found the culprit. but before that, there was no such issue?
Yeah b4 that no such issue... somehow after many of the app updates the Home app started running amok on the 9proFold, and it was warm to the touch after leaving idle for hours.
Other Android devices with Home app still fine/normal.
