alvinkhoo
android?
check unrestricted data access and mobile data usage--->mobile data allowed
might they have been triggered?
chari-men
done and reinstall too.
the issue is when i try wifi, singtel and eight.
both wifi and singtel can log in within 5 sec.
eight just couldn't log in.
i called uob earlier, they advised me to try wifi, but i said it doesnt make sense, as i was able to redownload the app from playstore. uob said they dont see me logging in all these while.
so true enough when i reached home and try it with wifi, it works. try my 2nd sim singtel, it works too.
come back to eight, and it doesnt log in.
What phone are you using??
ky0123
would like to port to eight as i travel alot to Vietnam - HCMC. Can anyone advise how is the network connection there? thank
mosmos
High Honorary Member
Reset your phone, most probably OS corrupted or component spoilt
Also uninstall all non playstore apps, gfk and disable developer option
sango65
anyway since abt an hr ago my mum is now on the $5 seniors plan. been testing it out and experience is the same as the $8 plan
hopefully eight allow seniors to sign up online, then allow their family members to collect the SIM card on their behalf at the SIM Card collection points.
eyz
it finally works after 3 days. thanks for the suggestions.
