Need recommendation for fire proof windows
parchiao
Don't need to explain this.
Just need whatever recommendation stop this kind of fire from spreading into my home.
:frown:
li9ht5peed
the fire is reddish orange from photos, so the temperature should be around 1000 degrees celsius
you will be safe with borosilicate glass. this is used in research institutes and in space shuttle exterior claddings. autoclavable and melts at 1700 degrees Celsius
Acetone
The one hard to stop lah… looks like the unit on fire is a smelting furnace. šŸ˜‚
hotamp
rather serious fire, dunno if any windows can withstand that kind temperature, even if there are cost wont be cheap and also the weight dunno can installed on to existing hdb structure or not.
hongge
Even if the fireproof glass can withstand the heat, the frame holding the glass may not and may melt under the heat.
standarture
Glass is technically not fire rated. Must be reinforced with wall and thick. And need to be cooled.
parchiao
If cannot keep the fire or smoke out
What can I do to minimise damage in the house?
:s11:
matrix05
Need to see the aftermath photo. Above and below windows and frame all melted.
The_King
:s11:
seriously, you can try to buy a few of this and place it in location you feel are a high risk area that on 24/7 like extension plug that is on 24/7, your fridge, router, battery storage area, ** box etc....
