Vivo X200 Series
berber
started experiencing the same issue these few days, play store downloads just stuck. today some downloads manage to work albeit randomly. almost wanted to factory reset the phone but good to know now that i'm not the only one!
KeYoKe
Not going to work after resetting either. I did it. Lucky my china rom phone is secondary phone
Those that have issue downloading, are you all on M1 broadband?
rinchan22
Yeah m1 broadband. Think only affecting Chinese rom phones. Tried on my magic v5 today. No issue using WiFi.
roidred
If ignore everything just for camera which should I buy Pro or Ultra. Got confused after watching video in some cases pro is better than ultra
berber
I am on m1 mobile and broadband. Tried the vpn trick someone mentioned and it kinda helped..
Shadow79
I have both and kept the Ultra. If you are comparing technical specs, the Ultra camera system is superior. Which one to choose (assuming both on CN ROM) then its really up to your shooting style. I don't shoot alot of ultra wide shots (14mm) but if you used to the wide angle (23mm to 25mm) used by almost all smartphones nowadays you will take a while to adapt to the 35mm on the Ultra. The good thing is 35mm have less distortion compared to 23mm-ish when shooting human subjects. If you need wide shots, can always select 2x zoom on the ultra wide sensor. It's using in-sensor crop when you select 2x (28mm) and most of the time most people cannot tell a difference but if you are always shooting on 23mm then the Pro image quality will be better. Night mode on the Ultra on the telephoto lens is also better due to the large aperture on the Ultra. And most importantly Vivo toned down the sharpening and contrast on the Ultra. On the Pro you can achieve the same by customising the settings and save it as default.
roidred
Everything was so technical have to read two times. Thank you 👍 will buy ultra
dreamcast18
ltrinityl
Hi all,
I recently bought the x200 pro (Global Funtouch OS)
I'm experiencing a very wierd issue. When I left the phone asleep/idle, the screen will randomly light up to the lock screen but I don't see any notifications at all.
Even when i unlocked the phone, there was no notifications that came in at all.
Have anyone experienced this issue or is there anyway to check what is wrong with it?
TIA
qhong61
Hi all,
TIA
How much u bought
chari-men
Hi all,
TIA
how often does it occur??
ltrinityl
Currently it's not happening.. It happens randomly which I don't know why and I can't even catch the timing.
Just now 9pm+ it lighted up and when back to sleep... 3 -5 mins lighted up again.. and back to sleep..
dodongdodong
