Android TV Box
gregory_choo
Thanks for your reply.
But sorry i mean to remap the buttons on the remote controller of the Mi Box Gen 2. I dont subscribe to prime or netflix and i also want to change the button for Youtube to Smartube.
Any idea?
there is an app called button mapper in the playstore, you can try it.
ridiculous?
Anyone's tv box producing buzzing sound? If touch the metal frame of the monitor, the sound is gone.
Using the 3.5mm socket on tv box, monitor and usb dac all produces noise.
:o
Lampard
Hi, any recommended tvbox or solution that can has giga lan port to stream 4K video using stremio ? Currently using direct ethernet connection for my Google tv but only can hit 1-3mbps in stremio.
gregory_choo
no point to go gigabit, if your current rate is 1-3mbps.
for stremio 4k video, normally 100Mbps is enough, as most its video are less than 50Mbps.
the current problem is not due to your ethernet connection. i.e bark at wrong treee
Philippng
DIYP definitely look interesting but i will have to wait till i get an mi box first.
Vidaa Store only have a good free one SS IPTV which i am using it atm
DIYP and SS IPTV is outdated, if you have got your mi box. now you can go for OKTV.
The best iptv, better than iptv extreme and ott navigator.
check out this for more details
https://iptv-tech-abox.blogspot.com/2025/03/free-iptv-for-smart-tv.html
It work best on Smart Google TV such as Prism, Sony, TCL and many others smart google tv
Lampard
I am on m1 2.5gb plan. But my prism tv ethernet I think is only 10/100mpbs. I tried connecting Ugreen ethernet 2.5 adapter to tv usb port but couldn’t work, that’s why looking for alternative tv box with gigabit to fast stream stremio 4K.
gregory_choo
You can only achieve 1-3Mbps on 100Mbps network
You will get the same 1-3Mbps even your box/ network is changed to 1000Gbps.
That's why I said bark at wrong tree.
By the way, you need only less than 50Mbps for 4k video from streamio. Less than 30Mbps from netflix/YouTube.
sweetpea
current viu on xiaomi tv can’t update but unable to see a newer version fr 202096, anyone can advise?
gregory_choo
no more update.
you can still watch on tv using the official way: play on hp first, then chromecast to mibox.
kottty
hi all.my Xiaomi tv p1 55 watching Netflix 4k video and Disney plus will laggy.is the tv processor issue? I'm quite sure not internet problem.should it get mi box gen 2 or 3?mi box comfirm no issue watching 4k video right?
Read HWZ Forum Rules!
gregory_choo
Go to settings
1. clear data for netflix
2. Uninstall netflix
3. Disabled netflix.
4. Go to play store and install and enable netflix.
5. Make sure the playback settings is in auto mode.
kottty
Go to settings
seem like updates version Netflix doesn't have playback setting.i remembered last like can choose to lower quality like hd but now seem can't
kottty
Go to settings
I really fix the laggy..thanks again :)
just didn't do step 5..can't find it anywhere
lazy999
Recently my svi TV app keep exiting and restart itself.. Asked the supplier, he mentioned might need a new TV box. Mine is mi box s 2nd Gen.
Any good TV box to recommend?
gregory_choo
Mibox s 2nd gen is a good TV box.
He tried to bs you.
lazy999
He tried to bs you.
Understand boss but no choice. Wifey want to watch her hk drama and I tried reinstall the svi cloud app. Still the same issue. Watched a while then exit out by itself. Any solution to this?
