Thermal Paste Specification Comparison
elmariachi
@Yongkit how about Thermal Grizzly Kryonaut Extreme?
i just got the paste but have not gotten around to replace it yet for my gpu...
longevity wise...
Don't use Kryonaut Extreme on GPU. It dried up very fast for me. These pastes are designed to be used for a one off benchmark run or sub-zero temps. Even for my CPU, it dried up so fast. Go for PTM for GPU. Paste and forget. Really.
deepblue_82
holy....................................... ssss ok thanks
Mach3.2
PTM7950 is really solid. used for more than 2 years on my 3080, the hotspot delta still hovers around 11-13 deg Celsius.
deepblue_82
guys beside beside using ptm 7950 on the main ihs
i still need to get the cooler pads right? to replace the mem parts?
12122012
:grin:
ragnarok95
Senior Moderator
Senior Moderator
I bought Kingpin KPX to replace. Coming this week and will change during the weekend.
MangoCAT
@ragnarok95 is this possible? --> My purpose is I don't want to adjust the airflow inside directly and want to push out less warm air by using [cold air sinks] too // not heatsink
(surfing the net)
MangoCAT
Sorry, i iphone user.
that is not answering - i want to create a dual tower SE if u see the asus pn53 vertically
nvm - got ppl do it before
My mini PC had an aluminium case with a flat top, so I placed a spare cpu heatsink i had on it. No tape or paste. Full load temps dropped by 10C.
MangoCAT
huh why tag me
that one the ssd sticking out like sore thumb sia
but if it works it works.. just dont break it
maybe is not you that also use mini pc
The temp was unstable when i put my iem box directly on top.
Thanks for free eye check - change to other side // Should be aluminum
Phen8210
wat iem? i got the truthear pure few mths back, quite good sia for the price.. v relaxing sound n have some detail which is quite rare for this kinda sound sig ( thx to the 3 way crossover ig).
MangoCAT
using timeless II. Most of truthear iem are auto pass for its price. Bought a TE:Gate for my niece to intro her into iem
soreloser
just used duronaut and replaced the amech sgt4, didnt see any form of discolouration on my heatsink yet.... but temps are lower with the duronaut so thats great
