DJI Osmo Pocket 4
RyanJ
https://m.weibo.cn/detail/5169798352994917
https://www.notebookcheck.net/DJI-O...-launch-with-Hasselblad-camera.1023897.0.html
https://www.gsmgotech.com/2025/05/exclusive-dji-osmo-pocket-4-rumored-to.html
" DJI is now tipped to launch a new generation of its on-trend dedicated vlogging camera gadgets soon. The "Osmo Pocket 4" is also now backed to be the first of its line to boast the premium co-branding typically reserved for the OEM's top-end drones. The news comes alongside claims of an even closer merger between the two companies in question. "
If they can reinforce the gimbal and fit some kind of "normal" focal length optical attachment that would be amazing.
Apparatus
The form factor of the Pocket 4 will be slightly larger than the Pocket 3
Accessories like protector case, expansion adapter, filters, stand base mount etc cannot be used liao
Jialat.............must spend money to buy new ones
:rolleyes:
Apparatus
Is this the new P4?
Apparatus
New photos just emerged. Pocket 4 should be released this coming late October to early 2026
Apparatus
Oh man ….. Shd I wait for this instead? :(
IMO, the Pocket 3/4 is no use. So far I saw one middle age man using the Pocket 3 in his hand and filming a close object recently at COMEX IT Show. And I have seen and touch the Pocket 3/Osmo 360/X5 as well at Funan Centre.
The screen is just too small. If the screen and camera are of one device you can't see what you are shooting if
1) use it on a tripod without the need to use your hp as a screen and controller
2) use it on a selfie stick without the need to use your hp as a screen and controller
3) mount it on your shoulder strap/chest without the need to use your hp as a screen and controller
This is also true of those action cams and 360 cameras with the screen and camera as one device.
Buy those where the screen and camera are detachable so can use the screen to see and control the camera. The Insta360 Go Ultra has a 2.5-in screen and now the Osmo Nano is releasing soon. Both have detachable screen and camera
