hereiam7788
- Dec 10, 2015
Sounds ancient.![]()
still enough to meet the needs. i can hit 600Mbps speed no issue on wifi.
and with wifi 5 tri-band mesh can still cover entire apartment decently.
Yeah, if no use case and meet your needs, no point to upgrade unless no longer economical.still enough to meet the needs. i can hit 600Mbps speed no issue on wifi.
What is the WiFi 5 tribabd mesh solution you are using?
The major worry of using old consumer WiFi router is usually on security. Many of the old routers are out of security support already. If that is the case, you are putting your home network under very real and serious threat.
For example, Asus has EOLed all WiFi 5 consumer routers. A few of them (eg: RT-AC68U and RT-AC86U) got exceptional uodates due to severe security issues this year but that is not the norm.
mine is linksys mr8300 tri-band mesh wifi routers.
| Product | End of Security Support* |
| E9450-SG | January 2027 |
| MX4200SH-SG | January 2027 |
| E8450-AH | February 2027 |
| E7350-AH | February 2027 |
| MX2001SH-SG | August 2027 |
| MX5500 series | March 2027 |
| MX4200-AH MX8400-AH MX12600-AH | March 2027 |
| FGW3000-AH | March 2027 |
| WHW030X-AH | April 2027 |
| MX200X-AH | April 2027 |
| MX4200 v2 | September 2027 |
| FGW5500 series | March 2028 |
| MX6200-AH | December 2030 |
| LN1400 | June 2031 |
| LN1100 v2 | June 2031 |
| LN1200 v2 | June 2031 |
| MBE70 | June 2031 |
| MR55WH | June 2031 |
| MBE7000 | July 2031 |
Even with wifi 8 router, do not think we can get better speed.The good thing is that MR8300 is supported by OpenWRT.
https://openwrt.org/toh/linksys/mr8300
Linksys Singapore does not seem to support MR8300 any more. So you may need to upgrade if you don't want to change to OpenWRT.
https://support.linksys.com/kb/article/434-en/
Minimum Support Period for Security Updates (Singapore)
Product End of Security Support* E9450-SG January 2027 MX4200SH-SG January 2027 E8450-AH February 2027 E7350-AH February 2027 MX2001SH-SG August 2027 MX5500 series March 2027 MX4200-AH
MX8400-AH
MX12600-AHMarch 2027 FGW3000-AH March 2027 WHW030X-AH April 2027 MX200X-AH April 2027 MX4200 v2 September 2027 FGW5500 series March 2028 MX6200-AH December 2030 LN1400 June 2031 LN1100 v2 June 2031 LN1200 v2 June 2031 MBE70 June 2031 MR55WH June 2031 MBE7000 July 2031
*Linksys will provide security updates for the products listed. Unless otherwise noted, the End of Security Support final day will be the last day of the month. Check the Linksys Support website for the most up-to-date information.
With the heat WiFi 7 devices are outputting now.... I can't imagine how warm the WiFi 8 equipments will be.... Especially the APsYes, when WiFi 8 is available (2028).
This is not because of WiFi 8 is much faster than WiFi 7 in terms of speed, since WiFi 8 is more about reliability and better roaming, not absolute near range speed.
1) Many more devices will support 6GHz and 320 MHz channel bandwidth, so it is easy to get above 2Gbps or 3Gbps WiFi speed.
2) MLO will get more mature. So you may see improvement on near range but more at far range.
3) 5Gbps and 10 Gbps plans will be the dominate plan and more routers will be compatible with 10Gbe, so your top wireless Internet speed will not be limited by the 1Gbps/3Gbps plan, or the 1Gbe/2.5Gbe LAN ports. So you will see 3Gbps WiFi speed becomes very common.
With the heat WiFi 8 devices are outputting now.... I can't imagine how warm the WiFi 8 equipments will be.... Especially the APs
Typo, what i meant is with the heat WiFi 7 devices are outputting now....Indeed that is an issue with Qualcomm/Broadcom/MediaTek still using the old semiconductor process with the IPQ957x (14nm), BCM4916 (16nm) and MT7988A (CPU for Filogic 880, 12 nm).
MediaTek started to use 6 nm process for the wireless portion of the Filogic 880/860 chipset.
Let's see if 6nm semiconductor process (or better ones) will be used by next generation WiFi 8 chipsets or not.
High heat = high energy loss also, so this is something that needs to be addressed. High power, low efficiency is bad for us.Typo, what i meant is with the heat WiFi 7 devices are outputting now....
Hopefully it will better. With my experience on U7 Pro XGS on 85 celcius, i now scare liao.
Even on Omada EAP 773 is on 45 celcius, EAP 783 on 55 celcius is quite high temp already.
Although i do admit one cannot deny that the heat output by those equipment which involves analog signal will have a high heat output
This is also why I chose to stick with U6 Pro. As the hardware iterates, the efficiency gains come later. Also, as adoption goes up, costs come down.
So looks like the fanless design of Ubiquiti U7 Pro XGS is not so suitable for the weather in Singapore...
They claim to have learned a lot from the U7 Enterprise or other higher end gears to improve thermal.
Guess that is all marketing...
Yup. Their APs mostly are hot one even their WiFi 6 APs. Unsure why as well.Actually there are also many reports over the internet claiming U6 Pro is hot ...
