Honor Magic V5
Jellyfishtan
a full phone restart make it work again :( not sure when it will come back. nowadays i watch youtube more on my mobile...netflix only watch on my lg tv..
Ohh. So it's something like a glitch/bug waiting to be resolved? Is it all along like that when this phone was released or due to recent updates then liddat? 🥲🥲
Jellyfishtan
I have no issue with Netflix tho... is ur account those shared password bought from online??
Nope. I subscribe through Netflix. But I not sure iszit because I update to the latest software version through the try out version? Honestly no idea though. But feeling a bit pek check if keep need to restart.
SuperDecker
I had the same issue before last firmware update. After the update, I uninstalled Netflix. Reboot. Reinstall via Google play store. So far it seems okay.
Ray1976
9.0.1.146 (C636E3R4P1H2)
Thanks...in that case, I am already on this version. The reason I asked is because yesterday evening I received a big 2.06GB update (yes, I just bought a new set)...hence when you said there is an update around 116MB. I thought this is a new firmware. I guess mine is a "combined" update, hence the bigger file size.
rinchan22
Anyone experiencing Netflix app keep crashing?
All along like that. Super annoyed by it so I sold it already. Battery got bug too? Always full charge immediately even though it's supposed to learn your usage.
maumu
I try to remove from charging once it hits 80+%... 90+%... depending on how closely I monitor the charging :o
anyway, I noticed my apps are always 'shut down' overnight. whenever I wake up the phone will seem like it was rebooted. how to check the settings ah?
doki81
Maybe exclude your app from the optimization then it will keep it run at background.
maumu
I have apps running in the background even though I'd closed them... but this case it's the apps are closed by itself (or by the system) overnight.
the thing is - it only happens overnight. anyway will try manual management... see if it will still close by itself or not.
SuperDecker
I got the Netflix error again yesterday. I think error code 5.7.0 and 5.10.0 if I remember correctly. Had to reboot the phone. But the reboot was fast. But it's an irritating issue.
The smart capacity battery feature looks deceiving to me. I enable it but just heck it and charge until I remember to plug off the cable.
Anyone noticed changes in battery life when it's disabled?
