MyRepublic Mobile discussion thread
grapewall
Wah...MR 4g speed damn jialat.. i don't expect much since it is using M1 network. 10+,20+ mbps i happy enough. But less than 0.1mbps?
I just did a speed test.. download speed is... 0.09mbps.
what kind of joke is this?
Think i need to port out again...
gapboy
sounds like "eight" plan speed
grapewall
I ported from Eight to MR...Eight is much better than this..at least still got 20+ mbps, which is quite decent especially this is a back up phone...
The reason I ported out is, after the Eight outage 2 weeks ago, I decided to convert one phone to another telco..
gapboy
i would use 1 x ST network if you want to keep Eight, MR 4g is under M1 ?
grapewall
yes... MR 4g is under M1...
I looked at ST mvno too..while the network is good, the deals are not so... since is a back up phone which I just wanted to keep the line alive, I go for the cheapest plan... MR one is $6 nia..
gapboy
Jirachi
MR services starts to decline this year. It was the best in 2023.
For ST, you might have to look at Zym or VIVIFI
AppleStrudelMudPie
Just went Malaysia yesterday again. I even purchased a roaming plan on top of my free roaming to see if it helps in any way. Still no roaming and data when I reached there. Contacted technical support directly through the previous ticket email and no reply for almost 24hrs already even though they mentioned they will get back to me previously so i dont have to go through the in-app support when i encounter the same issue. Very disappointed with MyRepublic.
froztheart
So totally no roaming at all? How did you email out them, through WIFI/hotspot?
Did they respond to you eventually?
AMD_Duron
Just in case, any need to activate roaming on the MR app? For me on ST MVNOs. There’s a need to activate on app and phone before heading in to use data roaming.
