endlssorrow
- Apr 11, 2007
To cover the front and bottom of the MacBook? Is it worth the effort or the low price like btw $9-$15 type from Shopee?
why need to cover?To cover the front and bottom of the MacBook? Is it worth the effort or the low price like btw $9-$15 type from Shopee?
Even those bottom got the stand to let off the heat also no use?used to but gave up, due to heat buildup worries
Or better to cover the front? HahaEven those bottom got the stand to let off the heat also no use?
Won’t be dirty mahwhy need to cover?
In the end the cover will also be dirty rightWon’t be dirty mah
Then can anyhow put on outside table ?
Easier n faster to wipe off mahIn the end the cover will also be dirty right
why having cover will be easier and faster to wipe off?Easier n faster to wipe off mah
if that's your concern then ok la.Machine itself will scare spoil or added too much water or solution when wipe or cleaning
M series chip no need to worry heat build upused to but gave up, due to heat buildup worries
then you havent drive it hard enough. mine is mostly on high fan speed despite having it on laptop cooling pad.M series chip no need to worry heat build up
What are you using it for?then you havent drive it hard enough. mine is mostly on high fan speed despite having it on laptop cooling pad.
