VIVIFI
A7997A
According to several accounts, Zero1 now has VoWifi/Wifi Calling, so does Vivifi have VoWifi now ?
hereiam7788
If before the next month bill oct to be charged, when is the latest date I must port out from vivifi to avoid additional charge for Oct bill?
hereiam7788
Yes, very good promo 9 months free for CL only. I tried all other telco, only 6 months free.
SO, if you are porting from any telco, other than CL, zero1 offer very close. It is valid till 31 Oct.
when u said other telco does it include eight etc.?
honestguy
For those of you on Roam Vibe, doing data roaming in China, the data roaming connection is not auto. You need to manually select network operator China Unicom or China Telecom.
The default APN, Singtel (Postpaid) will not work. You will need to create a new APN name with a different id and password, which can be obtained from Vivifi Customer service.
All these are not documented in their FAQs.
https ://help.vivifi.me/hc/en-us/articles/46582107820953-VIVIFI-Vibe
sbl2560
I am on Vibe 4G. There isn't a requirement to create a new APN. E-ideas worked fine.
Just need to manual select network. Tested in various part of China.
honestguy
Lucky for you. Our 2 phones cannot connect to Internet. Only can, after using the newly created APN.
i.Singaporean
Tried to port out to giga then back to Vivifi but giga say name/ID mismatch.. Vivifi say correct and shouldn’t have any issues..
Gonna try MyRepublic, anyone knows if they got minimum period before you can port out? (Circle Life apparently need stay for 2 billing cycles)
Thanks in advance
hereiam7788
Thanks in advance
my experience with vivifi port-in last time was that somehow the way the data of first name and last name are mismatch across telcos. maybe this is the reason why porting failed.
i.Singaporean
Yeah that what I thought too..
How did you solve it in the end? Get either the incoming or outgoing telco to change the sequence?
