tk
But my graphic card can't support hdmi.. Can't link to my prism TV. Any recomd ways to do it?
Graphics card got display port? I use a DP to HDMI adapter to connect my quadro p620 to my monitor..
heavenrave
Hi guys any recommendation
Games to play: Wukong, Diablo IV, Battlefield 6 upcoming
Purpose: Casual gaming and for work purpose with some movies. Multiple tabs while gaming and surfing the web
Monitor: 144hz at least for fps gaming (need to get 1 as well, any recommendation or even better)
Budget: 5k inclusive of monitor
Need a full fresh pc setup
thanks in advance.
abstrax
thanks in advance.
Just go AS or invader website u will get ur spec u want.
Are u getting 1080p monitor? if yes go for 200Hz above is well better since u got the budget.
Dranyeros
Hi all, I’m trying to buy a pre-built pc from Invader based on the specs of the midrange gaming rig in the first post of this thread. I don’t have any experience DIY, so just want to buy a pre-built one. I intend to use this for gaming (Diablo 4, Black Wukong, etc.) and light use of Microsoft Word/Excel, and my budget is around $1.5-1.6k.
I found this build from their website - I can’t post links but this is the Master M36 build (summary below). This allows me to upgrade the CPU to Ryzen 5 7600 for $1,316. Are there any other value-for-money upgrades that I should include (e.g., RAM, cooler, SSD, PSU) within my budget? Thanks!
Summary:
AMD RYZEN 5 8400F 4.7GHz PROCESSOR 5 7600 6 CORE/12 THREAD
ASUS TUF GAMING B650EM-E WIFI
DEEPCOOL UD551 ARGB CPU COOLER
CRUCIAL PRO DDR5 BLACK 6000MT/s 32GB(16GBx2) CL36
ASUS DUAL AMD RADEON RX 7800XT O16G GDDR6
ADATA LEGEND 860 1TB 6000MB/s PCIe GEN4 NVMe M.2
SILVERSTONE TRITON 750RX 750W GOLD ATX3.1 PCIe5
SAMA M203 BLACK TG M-ATX CASE
4 X 120MM ARGB FANS
HIGH-SPEED AX WIRELESS AND BT | WIFI 6 + BT 5.2*
WINDOWS 11 HOME UN-ACTIVATED
tk
Summary:
4 X 120MM ARGB FANS
Monitor is 1080p or 1440p? Rx7800xt is last gen, u may wanna consider rx9070 instead..
Dranyeros
I don’t have a specific monitor yet but I’m not too fussed about the monitor. Whatever specs fit best within the 1.5-1.6k budget would work.
I can see the FX 9070 option under Invader’s M56 build, but it doesn’t leave much budget for any upgrades of the other parts…
deepblue_82
if are not planning to game at 4k
7800xt is able to handle 1440p
-Synchronicity-
I would much rather go for 9060 xt 16GB though simply because of FSR4.
That said, if can stretch $100 more to 1.7k, the MASTER M57 with 9070 seems like a pretty good deal:
SGD $ 1,578.00​
AMD RYZEN 7 7700 3.8GHz 8CORE/16THREAD
MSI B850M GAMING PLUS WIFI
THERMALRIGHT ASSASSIN X 120 R SE ARGB
POWERCOLOR AMD RADEON REAPER RX 9070 16GB TRIPLE FAN
4 X 120MM ARGB FANS
HIGH SPEED AX WIRELESS AND BT | WIFI 6e* + BT 5.3*
Parts to consider upgrading:
PSU: MSI A850GL-850W (+$73)
RAM: TEAM T-CREATE EXPERT BLACK 6000MHz 32GB(16GBx2) CL30 (+$33)
Grand total after optional upgrades:
SGD $1,684.00​
abstrax
SGD $ 1,578.00​
4 X 120MM ARGB FANS
SGD $1,684.00​
dun tik the cpu cooler can suppress R7 7700. get a 240mm AIO cooler to save budget.
If u tiking to game for long hrs, AIO is a better cooling method.
I have a R7 5800X that use 360mm AIO when running AAA game can go up to 70++ degree anytime in no aircon environment.
-Synchronicity-
It is absolutely fine and does the job. Unless there's OC involved but that seems highly unlikely.
Yevin227
Hello everyone, looking to get a new rig. Budget around 1k with windows. Light dota2 gaming on 3440 x 1440, but that's about it.
I need it to run multiple research programs (think Nvivo, R, Minitab, SPSS), as well as the microsoft suite of applications. Sometimes will use Adobe Illustrator/Photoshop/Lightroom too.
I need to output to 4 monitors, can internal gfx handle that?
Any recommended builds?
starry_starry_night
Hi I'm trying to DIY a pc for my first time.
Shortlisted my psu, cpu, gpu and motherboard as tiagong these 4 are the most crucial components.
May I know is there any website whereby I can double check whether all the parts I selected are compatible?
