VIVIFI
A7997A
On Roam Asia Super plan, VoWifi didn't work, same setting on the phone but the free ST line works with VoWiFi
Thanks for the feedback, this is the line you recently port so is on 5G SA right ?
Then it appears that at this point only Zero1 has functional VoWifi.
A7997A
I ported in this month, confirmed got 5G SA, option is available on my iPhone.
Did you check if you are actually connected on 5G SA or just able to enable 5G SA mode ?
"dial *3001#12345#* and hit call to enter Field Test mode – this will provide specific details about your 5G connection and whether or not you’re getting Standalone service
Look for SA next to capabilities/connection_type"
vsvs24
I am now on Vivifi Roam value $7.70 plan. Just received email on upgrade to Vibe $10 to get 5G+ trial for 6 mths.
AMD_Duron
"dial 3001#12345# and hit call to enter Field Test mode – this will provide specific details about your 5G connection and whether or not you’re getting Standalone service
Look for SA next to connection_type"
Iphone so under capabilities shows SA+NSA. whereas my M1 line shows SA only
hereiam7788
Vivifi really make port in difficult.
When I ported in to vivifi, it will failz
when I want to port out to other telco from vivifi, it also fail.
wtf.
AMD_Duron
wtf.
I never had any problem with them so far. Been porting in and out without issue. Tell them to correct maybe your last name/first name or other particulars.
hereiam7788
every time I port in or port out also encountered the same prob. Not first time anymore.
A7997A
Ok, means the sim & phone is ready for both 5G SA & NSA.
But is the connection actually 5G SA ?
Asking as it seems that all 3 ST MVNO seems to imply that 5G+(5G SA) is not yet ready on their end and Zero1/Zym appears to be still giving out 4G sims for 5G plans.
