hereiam7788
- Dec 10, 2015
is iphone ios 26 call screening function available for MVNOs?
just need to log case with vivifi to fix this, nothing can be done at consumer side actually. they will resubmit port in request again.Yeah that what I thought too..
How did you solve it in the end? Get either the incoming or outgoing telco to change the sequence?
No one has a chance to test VoWifi on Vivifi so far ?According to several accounts, Zero1 now has VoWifi/Wifi Calling, so does Vivifi have VoWifi now ?
On Roam Asia Super plan, VoWifi didn't work, same setting on the phone but the free ST line works with VoWiFiNo one has a chance to test VoWifi on Vivifi so far ?
Thanks for the feedback, this is the line you recently port so is on 5G SA right ?On Roam Asia Super plan, VoWifi didn't work, same setting on the phone but the free ST line works with VoWiFi
Yes correct. Recently ported.Thanks for the feedback, this is the line you recently port so is on 5G SA right ?
Then it appears that at this point only Zero1 has functional VoWifi.
There is 1 report that got a 5G SA sim, but not clear if actually getting 5G SA connection.Anyone can confirm that all new sign ups and port ins will be on 5G+ which is 5G SA?
I ported in this month, confirmed got 5G SA, option is available on my iPhone.Anyone can confirm that all new sign ups and port ins will be on 5G+ which is 5G SA?
confirmed? your 5G SA option was not greyed out?I ported in this month, confirmed got 5G SA, option is available on my iPhone.
Did you check if you are actually connected on 5G SA or just able to enable 5G SA mode ?I ported in this month, confirmed got 5G SA, option is available on my iPhone.
I am now on Vivifi Roam value $7.70 plan. Just received email on upgrade to Vibe $10 to get 5G+ trial for 6 mths.
Confirmed. Not color blind so is green.confirmed? your 5G SA option was not greyed out?
Iphone so under capabilities shows SA+NSA. whereas my M1 line shows SA onlyDid you check if you are actually connected on 5G SA or just able to enable 5G SA mode ?
"dial 3001#12345# and hit call to enter Field Test mode – this will provide specific details about your 5G connection and whether or not you’re getting Standalone service
Look for SA next to connection_type"
I never had any problem with them so far. Been porting in and out without issue. Tell them to correct maybe your last name/first name or other particulars.
Ok, means the sim & phone is ready for both 5G SA & NSA.Iphone so under capabilities shows SA+NSA. whereas my M1 line shows SA only
Trial. Looking for Guinea pigs.The wording sounds like 5G+ is not yet available........
