Ceiling Fan Recommendation
van123
Unable to add newly bought bestar fan to smart life app.
Followed the steps given but keep saying failed or cannot find my wifi 2.4GHz network.
Mecisteus
I saw FB ad promos for KDK and Airer brands.
Do you have any other Smartlife devices ?
Or Bestar is the 1st one ?
Make sure wifi password is correct. And connect to the 2.4G network.
van123
Wifi password correct and it’s 2.4g network but it keep saying can’t find wifi
Mecisteus
Did you follow the pairing instructions guide ?
Is Wifi signal strong ?
Try bringing router closer.
Whatsapp to the follow Bestar support. They will send you the pairing video.
8875 1531
Invaaaaa
Anyone knows whats the recommended distance from the fan blade to the recessed ceiling downlight to avoid strobing?
elvintay07
Your ID will know. Depends on the light angle and also fan stem length etc. all mathematics but some lighting company can do simulations
coolhead
Managed to get 2 Alaska ceiling fans (1 Burah and 1 Curah) from Yafen store for $399 each. Quite a good promotion. Hopefully it will last.
elvintay07
Quite ex liao. Mecisteus less than $200 can get no1 brand Bestar. All of us overpaid liao for ceiling fan
