Thread all abt ROLEX - Part 2
ahsiao80
Anyone knows where can i get Rolex watch authenticated? And anyone bought from grey dealer, CWX Watches? Saw a Submariner, Feb 2024, $16.2k after discount, dunno worth to hoot another...
Prime 13
Is the rolex market collapsing?
Trying to flip a YM now.
No one ish buying.
Lolz.
unrealx262
Got a vintage Rolex datejust. Is it worth replacement case middle and back for $2700 which are optional? Bracelet 1650 and dial is $650. On the fence for the case works over bracelet but also concerned if I don’t replace the case and given sg weather corrosion will return ?
https://streamable.com/fu2rry
Rsc Watch analysis
Front case rim corroded, dial tritium worn and discolored, particle on dial, all case lugs worn, dial scratched, dial discoloured, hands corroded, movement malfunction, oscillating weight corroded, balance worn, bridge worn, case scratched, case dented, bezel scratched, bezel dented, crystal/glass scratched, case middle part corroded, crown scratched, crown dented, case back scratched, case back corroded, case back dented, lugs scratched, lugs dented, spring bars not manufactured by rolex, clasp/buckle scratched, bracelet worn, bracelet scratched, bracelet corroded bracelet modified
wanker88
Honestly if want to bundle, might as well go grey unless you want the AD experience.
I think the SA still thinks they have a lot of holding power in current market situation.
How's the market with AD now? I don't see the usual crowded ADs when I'm at Taka or Paragon.
potato13
Slow.. but still popular watches still need ""waitlist"" bundle etc..
Should have some normal DJ or non popular watches that can get (depending)
No harm walk in and try.. i would say..
Password123
Picked this up today. Got a freebie penguin for my newborn as well!
Prime 13
Yeah the 40 one.
40 ym is good.
37 ym ish a shitter.
Too small for men.
Too large and not elegant enough for women.
不男不女
Really regret picking it up.
Hassle of disposing it ish not worth.
All things considered, should hab picked up a tudor instead.
At least that one i will keep for personal use.
2h_jtta
Heard from one THG SA that it is confirmed that Emperor's Rolex AD status has been removed but not sure when they will continue operating until? But what I'm concerned are the watches they are holding in the safe will be sold before they close?
