VIVIFI
gapboy
circles so many interns to fire? so the intern went to vivifi?
Graduates not getting jobs prefer a non 9-5 routine jobs ... Professionals getting laid off (nowadays), so an internship is the only alternative for those finishing school.
A7997A
Any one with experience with both Vivifi's web management vs Zero1's can comment on how they compare ?
AMD_Duron
Vivifi no app. Purely web based. Zero1 is via app. Vivifi login via credentials. Z1 is the same plus option to login via OTP.
davi502
would personally prefer the app. It seems like the login site for VIVIFI is currently down?
A7997A
This depends on preferences.
Each app is both a potential security risk as well as a battery drain risk. For something that I don’t need to see everyday I rather not need to use an app. Having that option is nice, being forced to use the app is a problem.
AMD_Duron
Yes, one of the bothersome part is that the Vivifi dashboard often seems to go down, but oddly, it works if I change browser, so I tend to believe it is not really down but could be browser cookies related.
AMD_Duron
app is just easy to use and login..website abit more manual login both works the same tbh..
You are right that it works the same, actually no diff for me too, I save the passwords in the vault so it autofills. The vivifi login tends to be a bit slower due to refresh, Z1 app feels faster for me.
gapboy
ya website just save as bookmarks i used to be on vivifi before zym...
sbl2560
Agreed. Used to clear cache for Vivifi, then able to log in. Anyway, what is there to check for local usage? It is the roaming usage that when abroad, is of any concerns.
