gapboy
409mbps only ah.
more reviews to come since now 5g ? those worry about battery drain good luck
BBCWatcher
This month upgrade to $14.80 to test, next month downgrade to $8 can? :s13:
You can do that, but you really should wait until you're very near the end of your current 30 day cycle. When you switch to a new, more expensive tier level you lose whatever number of days/hours you had remaining in your current cycle. (When you switch to a less expensive tier, that change will be effective at the end of your current 30 day cycle.)
Habrosus
Good tip, thank you for the reminder! (y)
