I don't see that optionClick on the "buy with $5 voucher"
Can screenshot?I don't see that option
I think the one u have is a $3 no min spend voucher.. not everyone has it.. randomly given one...Can screenshot?
M1 maxx still cheaper
409mbps only ah.
409mbps only ah.
This month upgrade to $14.80 to test, next month downgrade to $8 can?more reviews to come since now 5g ? those worry about battery drain good luck
very canThis month upgrade to $14.80 to test, next month downgrade to $8 can?![]()
Nah!
You can do that, but you really should wait until you're very near the end of your current 30 day cycle. When you switch to a new, more expensive tier level you lose whatever number of days/hours you had remaining in your current cycle. (When you switch to a less expensive tier, that change will be effective at the end of your current 30 day cycle.)This month upgrade to $14.80 to test, next month downgrade to $8 can?![]()
Good tip, thank you for the reminder!You can do that, but you really should wait until you're very near the end of your current 30 day cycle. When you switch to a new, more expensive tier level you lose whatever number of days/hours you had remaining in your current cycle. (When you switch to a less expensive tier, that change will be effective at the end of your current 30 day cycle.)
How to fight with M1 Maxx..
