- Aug 8, 2012
Agreed, but the promos not giving 50% yet though from what I have seen.Once can cross 50% off or more, think good enuf liao
At most is just back to "Early bird" pricing kind of discounts.
Agreed, backgrond draining quite high.X6 pro battery draining quite fast.
Only background running app is WhatsApp for the notification.
Not sure why...zzz
Thought of changing battery. Not sure if it's the battery.Agreed, backgrond draining quite high.
Idle for a day, the battry can be half gone one...![]()
Try toggle off most of the apps notification if not required and see if it helps.Agreed, backgrond draining quite high.
Same apps going on, recently started this draining so likely the battery/MB/BMS sot liao.Try toggle off most of the apps notification if not required and see if it helps.
X6 still pretty new eh, but yes, the battery drains faster than my other POCOsAnyone changed battery yet? Has it improved?
Ya..that's the irritating partX6 still pretty new eh, but yes, the battery drains faster than my other POCOs
X7 pro got bigger batter capacity, that's why is heavier than x6 pro.Poco X7 Pro seems to be better in terms of battery life than Poco X6 Pro.
Now we have two Poco X7 Pro and two Poco X6 Pro phones in the family. But the latest purchase with 11.11 Shopee offer has not been opened yet.
Is it a 5G phone? if it is, it can be switch to 4G as an option as it does not drain the battery.X6 pro battery draining quite fast.
Not sure why...zzz
5G phone but I'm still on 4G plan until end of the year.Is it a 5G phone? if it is, it can be switch to 4G as an option as it does not drain the battery.
