WussRedXLi
- Jun 15, 2001
this morning's heat and temp imo still manageable. did a 12k tempo after 10am on a 60-70% shaded route.
personally my own protocol is to ease into the run. use the frist 1.5-2km to reach target pace then monitor heart rate (usually it will stablise and settle into a slow drift upwards).
if hr does not settle by 3rd to 4th km... its a early warning sign. I typically slow down the pace and see if it settles. If not will stop and fight another day![]()
My main limiter i think is the heat, for > 5k distance. This morning not the first time already, back in 2023 when i was trying to sub-40 10k i first few times also experienced this at the 7-8k so around the same as today's 6.5, before i tried that active cooling with iced water / towel and loops, the advice that i gave to you also.
So i think in a certain way, no way i can do things like sub 1:30 or sub 3 even if i trained for it unless i go all out with heat training. Quite sensitive to heat compared to others.
Heh hehe.........i think partly also coz of my office. I always put digital thermo at my desk, sometimes get too cold and i will tell the admin to tell building mgmt to adjust central. It gets to 20.5 deg C, pretty cold.
And also that i wear sports top "lycra" for my t-shirt.....coz i run to work and lunchtime and then back, 1.1k bt home and office. So in office it would be pretty cold, until sometimes if i dont move i'd even need to put on windbreaker.
And then "training" in server room lagi colder, 14-18 deg C.
And at home, wife would switch on AC from 7.30pm onwards. I pang kang at 6 and reach home ~ 6.12-6.15 depending on the office and home lifts.
And then of coz for cycling, the higher windspeed vs RPE and associated heat generation also means not much heat training, esp since riding is almost done early morning and nights, save for the weekends with some slight exposure to the sun (but usually we choose shaded as much as possible)
