doki81
- Jun 11, 2010
if have issue...cannot roll back. i scareJust install lar...should be fine. I didn't receive this new firmware alert at the time of this post.
you mean magicOS 10? it will still push to you just that you install it. so far, i always chiong to install it. you must have confident with them......so far to you see them fail u???? except 2 most famouse brands....their user all dare not to install even after numerious updates.....lolif have issue...cannot roll back. i scare![]()
i mean if anything wrong..i want rollback to stable os 9...cannotyou mean magicOS 10? it will still push to you just that you install it. so far, i always chiong to install it. you must have confident with them......so far to you see them fail u???? except 2 most famouse brands....their user all dare not to install even after numerious updates.....lol
Buy another v5 standby and clone... If anything goes wrong sell the beta one lol ..i mean if anything wrong..i want rollback to stable os 9...cannot![]()
dont want to get another phoneBuy another v5 standby and clone... If anything goes wrong sell the beta one lol ..
i change my region to msia and then sign up for beta...download took a while to complete. installation took around 5 mins.I still didn't get the new firmware...
So Singapore not one of the beta testing region in Asia market.i change my region to msia and then sign up for beta...download took a while to complete. installation took around 5 mins.
Singapore is under 'Global'.So Singapore not one of the beta testing region in Asia market.
Yep...this is the worst region where Honor simply dumped every other countries not listed in the mian list. LoL...and there is no beta program to sign up.Singapore is under 'Global'.
1st one for brigtness , dont think have quick tool to toggle. 2nd one, can use the parallel space to have your 2nd game in there for another account..do honor UI got like similar Samsung like quick tool swiped left or right u get access to toggles sound brightness example
beside swipe down from top of screen
and do honor os let u clone app games so can run dual app. as I know dual whatapp possible but games are not
you should be using parallel space which will clone another android environment.Anyone has any problems with the screen so far?
The dual app is limited to only a small list of apps?
thats impressive.The battery life quite lousy while on beta for the first day. Now started to improve a lot. Standby drain overnight with airplane mode.. 1% only.
