alex22
Hope the public opinions will stop the merger. If the authority needs public opinions, it means they are not sure whether it is good to approve the merger...
Just a 程序。
Public Consultation is an established process, SOP
Habrosus
Me me! Changed to 5G because only $3 more per month. $3 can't even get a decent meal nowadays. :o
I meant the Eight staff or Eight FB admin who replied that they'd no plans for 5G in August(?). :grin:
What's the story with iPhone 12 ?
I have seen mention that it is not compatible with 5G SA but from iPhone specs 5G SA is there.
Only iPhone 12 series and later support 5G.
twosix
Chatgpt:
Yes — iPhones in the iPhone 12 line do support 5G.
However, there is a caveat: models sold in Singapore (and generally outside the U.S.) only support the sub-6 GHz 5G bands (not the mmWave bands).
So in practice:
  • You’ll be able to use 5G with a Singapore carrier that has 5G coverage
  • You might not get the ultra-high speeds available via mmWave (if that’s offered in your area)
  • Your 5G experience will depend on the carrier’s 5G deployment (which bands they use)
If you like, I can check whether your specific carrier in Singapore supports the 5G bands used by iPhone 12. Do you want me to check that?
A7997A
Chatgpt:
So in practice:
I treat anything generated by AI as garbage until they have been vetted by a real human :)
I have seen it creating totally nonsensical relation that any human would not have done.
For some reason, Singtel/Starhub/M1 all do not list iPhone 12 as supporting 5G SA, and I wonder why :
https://www.m1.com.sg/sites/true-5g/index
https://www.singtel.com/personal/products-services/mobile/5g-plus/5g-sa-compatible-phones
https://www.starhub.com/personal/support/article.html?id=zrOyoFwU3L7RDXnmGqMsLA
https://www.vivifi.me/5gplus/?_gl=1*1t2n73r*_gcl_au*MTIxNzY3MjY3Ni4xNzU2MzQzNzAy
https://zero.zero1.sg/announcement/device-compatibility-guide-5g-sa-supported-devices/
Apple's does mention iPhone 12 supports 5G standalone with a caveat :
With iPhone 12 models, Low Power Mode disables 5G Standalone (where available).
https://support.apple.com/en-sg/108383
CPTMiller
NSA or SA no big issue. WIdth of the spectrum is the issue.
Like Singtel, using 100MHz spectrum. Running both NSA (for ZYM, vivifi) and SA, speed all very fast, can reach 1Gbps.
But SIMBA, only has 10MHz spectrum. No matter NSA or SA, speed confirm lower than the other 3.
Don't think SIMBA can access SH-M1's 5G 100MHz network, that considered pre-marriage property right?;)
As you mentioned Simba 5G network not up to the mark. Unless they use M1 resources or spend money upgrading their own network.
I believe Eight here will win in 5G performance for now
Revolee993
If you don't renew your plan by 30 days, your number will enter a 60-days grace period.
Does Eight allow users to port out when their numbers are in the grace period or will I have to pay another $8 to renew the plan again to be able to port out?
Only planning to use Eight as a stepping stone for a mth.
jase07
when will Eight include China and HK part of the their apac roaming man.....
BBCWatcher
Presumably it’s just a question of competition and costs. With Eight, China and Hong Kong are “Group A” roaming countries, so there‘s an included allotment with every plan (including VoLTE support in mainland China). SIMBA includes more data in those places, but SIMBA also starts at $10 instead of $8 (except for age 60+) and has a generally weaker network in Singapore. (SIMBA pioneered generous included international roaming precisely because it started with a weaker local network. Their network has improved, and it’s quite decent now. But it’s still generally regarded as the weakest.) M1 Maxx treats China and Hong Kong similarly, but Maxx offers less international roaming overall (many fewer destinations) and doesn’t have a $5 senior plan.
Frequent travelers often prefer having a +852 or +86 number (a second SIM), and Eight can’t really help with that.
It’s much the same reason why the vast majority of credit and debit card issuers in Singapore charge ridiculously high foreign transaction fees: because they can get away with it, so far. Vote with your feet! Switch to a card (or mobile plan) that works better for you if you’re not happy. (Trust Bank’s debit and credit cards offer zero foreign transaction fees.)
twosix
I checked the source it quoted. It is from Apple sg support website. I also try to verify before i post. This is the singapore apple website: https://support.apple.com/en-sg/111876?utm_source=chatgpt.com
A7997A
DigDub
5G speed test at second link msia side on Celcom network.
gaoqikai
iPhone 12 models were perfectly capable of doing 5G SA.
For example, in the US and China, iPhone 12 models run 5G SA no problem.
In Singapore, it is the MNOs that don't want to enable SA for these phones. MIght be because they want to sell new phones?
proof:
1. carrier bundle for 12 Pro, China Mobile
<key>Enable5GStandaloneAfterUpgrade</key>
<true/>
<key>Enable5GStandaloneByDefault</key>
<true/>
2. carrier bundle for 12 Pro, US T-Mobile
<key>Enable5GAutoByDefault</key>
<true/>
<true/>
3. carrier bundle for 12 Pro, singtel
<true/>
(no standalone)
JAYSCS
It's someone's field observation this past July. But why would it be surprising if SIMBA lit up a bit of 5G SA? Mobile carriers frequently run trials and tests. And they occasionally make mistakes.
...And do many people care? "5G SA" on a phone display doesn't give most people org*sms.
Er... i wonder which network will even give people org*sms at all, no matter how you use your device. 🤔
koreanlover
Anybody went to JB recently?
My phone can hardly connect at R&F mall, tried to manually connect to other telco also cannot.
I walked back to JB Sentral, more than halfway back then I could see 4G.
Today went to R&F again.
No problems with roaming lol.
