Sony Xperia 1 V
guangzong
can someone help me test??
last time can shoot stills while doing video recording.. that option disappeared lioaos
Just tested.
I am on 67.2A.3.115.
Using Photo Pro, in Basic mode, when recording a video, i can see the (stills) shutter button on the left of the record button, and use it to capture stills.
Photo Pro version: 1.7.2.A.0.9
darkmatt
Just tested.
hmm.. whats your camera settings? 4k also? anything else? one android update "removed" it
guangzong
Found the cause.
Go to Menu.
Video size: Change it from 4K 120 fps or 4K 60 fps to either 4K or Full HD.
You will now be able to capture stills during video recording.
If set to 4K (120 fps) or 60 fps the option will not be available.
Also, under HDR/SDR format, make sure you set to SDR.
In HDR, you will not be able to capture stills during video recording.
darkmatt
Found the cause.
Go to Menu.
Video size: Change it from 4K 120 fps to either 4K or Full HD.
If set to 4K (120 fps) the option will not be available.
I didnt change any settings. dunno why "run"
Kitaro9202
My phone went haywire liao.
Suddenly cannot take screenshot and my phone on standby mode but screen keep flashing despite no notification
GeSteSoh
Found the cause.
Go to Menu.
Hey it works! Full HD 120fps can't but 60 fps can. Thanks for sharing. (y)
