- Sep 16, 2018
Ahh /56
Polly you can post your OpenWRT configs here, so others may help chip in and try nailing it as well:
# cat /etc/config/network
# cat /etc/config/dhcp
# cat /etc/config/firewall
# ifstatus wan6
Here are the settings (removed wireguard stuff and static IPv4 address assignments to make the things shorter). I have tried /60 or /64 for the LAN/LAN2 but that does not matter.
Bash:
root@openwrt38:~# cat /etc/config/network
config interface 'loopback'
option device 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fdac:f49f:363d::/48'
option packet_steering '1'
config device
option name 'br-lan'
option type 'bridge'
list ports 'eth0'
config interface 'lan'
option device 'br-lan'
option ipaddr '192.168.38.1'
option netmask '255.255.255.0'
option ip6assign '60'
list ip6class 'wan6'
option ip6hint '0'
config interface 'wan'
option device 'eth1'
option proto 'dhcp'
option peerdns '1'
config interface 'wan6'
option proto 'dhcpv6'
option reqaddress 'try'
option reqprefix '56'
option norelease '1'
option peerdns '1'
config interface 'tailscale'
option proto 'none'
option device 'tailscale0'
config interface 'zerotier'
option proto 'none'
option device 'ztyqbuckbd'
config interface 'lan2'
option device 'eth2'
option ipaddr '192.168.78.1'
option ip6hint 'f0'
root@openwrt38:~# cat /etc/config/dhcp
config dnsmasq
option domainneeded '1'
option localise_queries '1'
option rebind_protection '1'
option rebind_localhost '1'
option local '/lan/'
option expandhosts '1'
option cachesize '1000'
option authoritative '1'
option readethers '1'
option leasefile '/tmp/dhcp.leases'
option localservice '1'
option ednspacket_max '1232'
option domain 'mypfddns.duckdns.org'
list server '/mask.icloud.com/'
list server '/mask-h2.icloud.com/'
list server '/use-application-dns.net/'
list server '127.0.0.1#5053'
list server '127.0.0.1#5054'
list server '127.0.0.1#5055'
option doh_backup_noresolv '-1'
option noresolv '1'
list doh_backup_server '/mask.icloud.com/'
list doh_backup_server '/mask-h2.icloud.com/'
list doh_backup_server '/use-application-dns.net/'
list doh_server '127.0.0.1#5053'
list doh_server '127.0.0.1#5054'
list doh_server '127.0.0.1#5055'
option serversfile '/var/run/adblock-fast/dnsmasq.servers'
config dhcp 'lan'
option interface 'lan'
option start '100'
option limit '150'
option leasetime '12h'
option dhcpv4 'server'
option dhcpv6 'server'
option ra 'server'
list ra_flags 'managed-config'
list ra_flags 'other-config'
option ndp 'relay'
config dhcp 'wan'
option interface 'wan'
option ignore '1'
config odhcpd 'odhcpd'
option maindhcp '0'
option leasefile '/tmp/hosts/odhcpd'
option leasetrigger '/usr/sbin/odhcpd-update'
option loglevel '4'
config dhcp 'lan2'
option interface 'lan2'
option start '100'
option limit '150'
option ra 'server'
option ndp 'relay'
root@openwrt38:~# cat /etc/config/firewall
config defaults
option input 'REJECT'
option output 'ACCEPT'
option forward 'REJECT'
option synflood_protect '1'
config zone 'lan'
option name 'lan'
option input 'ACCEPT'
option forward 'ACCEPT'
list network 'lan'
list network 'wg_lan'
list network 'lan2'
config zone 'wan'
option name 'wan'
option masq '1'
option mtu_fix '1'
list network 'wan'
list network 'wan6'
config forwarding
option src 'lan'
option dest 'wan'
config rule
option name 'Allow-DHCP-Renew'
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
option family 'ipv4'
config rule
option name 'Allow-Ping'
option src 'wan'
option proto 'icmp'
option icmp_type 'echo-request'
config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
config rule
option name 'Allow-DHCPv6'
option src 'wan'
option proto 'udp'
option dest_port '546'
option family 'ipv6'
config rule
option name 'Allow-MLD'
option src 'wan'
option proto 'icmp'
option src_ip 'fe80::/10'
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
config rule
option name 'Allow-ICMPv6-Input'
option src 'wan'
option proto 'icmp'
list icmp_type 'echo-request'
list icmp_type 'echo-reply'
list icmp_type 'destination-unreachable'
list icmp_type 'packet-too-big'
list icmp_type 'time-exceeded'
list icmp_type 'bad-header'
list icmp_type 'unknown-header-type'
list icmp_type 'router-solicitation'
list icmp_type 'neighbour-solicitation'
list icmp_type 'router-advertisement'
list icmp_type 'neighbour-advertisement'
option limit '1000/sec'
config rule
option name 'Allow-ICMPv6-Forward'
option src 'wan'
option dest '*'
option proto 'icmp'
config rule
option name 'Allow-IPSec-ESP'
option src 'wan'
option dest 'lan'
option proto 'esp'
config rule
option name 'Allow-ISAKMP'
option src 'wan'
option dest 'lan'
option dest_port '500'
option proto 'udp'
config zone
option name 'vpn'
option masq '1'
list network 'zerotier'
config forwarding
option src 'vpn'
option dest 'lan'
config forwarding
option src 'lan'
option dest 'vpn'
config zone
option name 'tailscale'
option masq '1'
option mtu_fix '1'
list network 'tailscale'
config forwarding
option src 'tailscale'
option dest 'lan'
config forwarding
option src 'lan'
option dest 'tailscale'
