Recommendations for a new PC Build
Animagamer
if pricing is a consideration. peerless assassin 120 se is perfectly fine for a 9800x3d, i use an RP130 and it doesnt really get hot, 50C usually in games. Just take note that the mobo will be considered to have no warranty
Ya i did consider the mobo as no warranty and i can save at least 50% discount. I found that the phantom spirit evo digital have a height of 160mm i am guessing it better to get that or aio
Personally i dun really like the 2 tubes of the aio
My PA120 Digital
Your build is darn nice and have a gundam as a figure is that the thermal right fan casing?
Some aircoolers nowadays also getting "cooler" aesthetically
Ya and the price is cooler 100sgd without shipping etc .
Vanyel
if want blinkblink means must pay extra for it no choice haha
for me this looks better than the aio with 2 very distracting tubes inside
my casing+fans from taobao
built earlier in mar this yr
initially was using Thermalright PA120, switched to the digital one a few months ago
PC rig Building/Upgrade again
DriftKing
Getting lian li o11d v2 mini that have 9 case fan 5 reverse and 4 normal maybe use a few hours per day
If you want get unactivated and get the key from Lazada or shopee
Can I carry my old licence from way back (Windows 8) that I'm using now and login to activate in a new build?
Animagamer
No idea, but i dont think so.
Is your license an oem key? if so high chance you need to get a new one
if not maybe google around
My idea was stealth with a LCD screen as the only bling and info, I did look at the Thermalright PA120 digital that you recommend, it is over by 2mm. I wet to bili bili to find anyone with the AIR Cooler and did one with a air cooler height of 159mm looks good. I do understand your view, no tube and it is clean
Could try to get PS120 Vision which cost 100 SGD after shipping
Vanyel
This one meets ur 160mm height requirement
Phantom Spirit 120 DIGITAL EVO - $64
send by air is at most +$10 including GST i believe
*ok i just tested on my phone direct air is $76, conso air is $72
but ya vision has a nicer full digital screen, definitely go for vision over evo
i thought both were the same, my mistake
jinsatkilife
any idea for ram, where would be the best place to get for cheaper price?
taobao got sell ram? what chinese terms to search
Koenig168
If you see something you like, just pull the trigger.
Just saw this on my Amazon.sg cart. The item was S$2xx 3 weeks ago so second price increase in less than one month. Seller is Tech Dynamic (the distro)!
jinsatkilife
how to find and get amazon promo ah?
i rmb last time got 12pm and 12am coupon
but now dont even know where to find...usually I assume dont have
