WussRedXLi
- Jun 15, 2001
Had to cut short the run to send the chewren to school.
Healthy dist n duration. Continue the routine and keep posting,
For those who do not dig dry scooping creatine powder, can also try sardines. One of the highest sources out there, take about 150g of sardines daily, shd be sufficient. Unfortunately, while sardines is super good, majority of people would still find 150g of sardines a bit overwhelming. But a strategy might be to take a bit of sardines and top up the rest with say 3g of creatine powder for those with sensitive stomachs (flatulence, diarrhoea etc)
It contains around 5-10X that of chicken/pork. If you try with chicken, sure over-protein by a fair bit, ie at least 1.4kg of chicken meat. (250g of chicken meat is all that i need to hit 1.2g/kg of protein)
Sardines is a good source. There are also a few others with higher creatine, like herring, pork, beef, tuna and salmon, as per chatgpt.
Old liao better not la. Not as though train the fingers so strong will help in anything. Once injured very hard for us to recover.
Can start with wall supported hand stand. Put tilam or thick thick exercise mat in front for safety.
Some people very agile. The leg just fall in front like somersault then back on feet.
Last time I train very clumsy one. Will get stuck, don't know how to come down. End up legs slowly crawl down from wall. If not careful, then crash onto tilam.![]()
Wah lao, Mica training to sub 2:30 at the end of the year
But then, got chance i guess. 5k 15:32 10k 32:28 HM 71 mins.
Yeah....somemore > 5g (eg 10g) is recommended for the cognitive benefits.
I just use 7-8g, 10g not so easy to take daily without significant flatulence. Already splitting into 3 doses.
That's one of the main drawbacks.
Come to think of it, now need to call my father to see if he has been taking + at the correct dosage, every now and then need to confirm, coz really really elderly.......
To me, got eat until 5g per day good enough. If nature (food diet) doesn't give so much creatine then i think no need to force or overdo it. If really so good, govts and hospitals would have strongly recommended it.
Nothing new here, but just came across another vid......
BMD of cyclists is really an issue. Significantly lower than even sedentary people. This is so even for sports cyclists in their teens and beginning to show signs, in the vid there was a case in which the teen is officially classed as having osteopenia.
Not sure what is the root cause. But one theory is that there is (1) no eccentric loading (unlike running, skipping, gym). (2) Cycling is ultra low impact.
The problem is also that cyclists generally dont like running + strength training.
But to be fair, the general population that do not exercise (or exercise sufficiently) / strength train also not that good. Just google the local stats...all there
Luckily i no issue with running (though mileage not really a lot, but still on par with regular exercisers) and no issue with strength training, hopefully sufficient enough.I told some local cyclists, dun want listen. Want to chiong cycling performance.
Other then the points you made, I can add is cycling is basically sitting down throughout the 1 to 2 hours of training. Carrying your body weight is itself a load bearing effort at base level.
