RIP Windows 10
matt1618sg
So long Windows 10. RIP. Fork you, Windows 11. Fork you, MS. Time to move on. MacOS, Linux, FreeBSD, here I come...
RyanJ
coyote
Just Google Rufus Windows 11 and your problem is solved. Cursing and swearing don't help. Taking action does. For the umpteen times, Google "Rufus Windows 11".
savoirex
did anyone check wat win 11 ish doing in the background? suspect its not OS related tasks... :s13:
banbleh
Windows 11 also does stupid annoying things like back-upping all your files to their cloud and deleting them from your physical drives. Then they'll tell you your OneDrive is full, please pay them money to upgrade your storage. Then you change the settings to not backup anymore, but the next windows update it resets the settings again and does the same sheet. It's basically a ransomware virus. So annoying.
matt1618sg
I know all the bypass tricks. I also know how to make and install Tiny11. I've also installed before Windows 10 Enterprise LTSC IoT. Come to think of it, maybe I should install Windows 11 Enterprise LTSC IoT on my spare laptop just for fun. IoT version is clean, bare bones, and supported for 10 years. You can get LTSC key online easily, cost about S$30. But really I've given up on Windows coz of the garbage MS is forcing down our throats like CoPilot and Recall.
Have y'all noticed Windows 11 uses 3GB RAM after you boot and without opening any app, ie just idling. WTH is Windows running in the background that needs 3GB RAM?! Compare to my daily driver - Debian 13 with XFCE DE - which only uses <1GB RAM idle.
zzzzzzz
today hear a radio ad for eletric store using win 10 eol to advetise for consumer to buy new one
:frown:
coyote
Ok. If you prefer Linux, go ahead. Most of my computers are dual boot Ubuntu and Win 11. I am also buying cheap second hand PC that comes with 16G rams at cheap prices. I think I still have another 8G ddr4 stick lying around. Memory is cheap.
No point complaining.
