I enjoyed doing them. Getting old, do bodyweight training to keep healthy.Why need to do pull up?
65 considered very good lo. Got one time, I push to 221 then all sorts of problems come. Tennis elbow, shoulder impingement relapse.Everyday 100? That's amazing. I can only muster 65 at best.
Start with 15 - 20 first then gradually reduce rep in each set till hit 100. Rest around 1-2 min in each interval. Usually the arms oredi numb by 60 reps, just keep cranking as much for completion.Throughout the day, or in one session? How many sets and reps per set? Rest in interval?
15-20 in first few sets is incredible! So is your rest interval being so short. For my routine I can only manage 5 sets: 5,5,5,4,4(or 3). 3 min rest.Start with 15 - 20 first then gradually reduce rep in each set till hit 100. Rest around 1-2 min in each interval. Usually the arms oredi numb by 60 reps, just keep cranking as much for completion.
What's your weight? Mine around 67kg. If you maintain consistency, your reps will go up gradually.15-20 in first few sets is incredible! So is your rest interval being so short. For my routine I can only manage 5 sets: 5,5,5,4,4(or 3). 3 min rest.
Sleeve tattoo?
Yes.Sleeve tattoo?
65kg. Thanks for your encouragement. My max rep is around 7-8, so trying to break 10 by this year hahaWhat's your weight? Mine around 67kg. If you maintain consistency, your reps will go up gradually.
Jin satki manzYes.
Amazing you both.Everyday 100? That's amazing. I can only muster 65 at best.
Try this method. Whenever you see the chin up bar, push to your max in single set. Say 8 reps, 3 times a day. Morning, Lunch and Dinner. 2 weeks later push for 9 and so on.65kg. Thanks for your encouragement. My max rep is around 7-8, so trying to break 10 by this year haha
Everyone started from 0 mah.Amazing you both.
I can't even do one.
