- Aug 8, 2012
Yes, same logic, cut off when used up.Thanks for the reply!
Do you also happen to know how they charge for exceeding roaming calls?
I saw an older post regarding roaming data — if you exceed the limit, the internet just gets cut off, and you don’t get charged extra. I’m wondering if the same applies to roaming calls. If I exceed my VoLTE or IDD minutes while overseas, will the call just stop, or could it incur additional charges? I just want to avoid any bill shock.
Thanks!
Unless you have balance to deduct in your wallet.
