Debloating Android phone
Foetid
I realise i have 200+ apps in the phone.
Even if buy a new phone, the data transfer over, it will be the same.
ur 200 apps, u can directly remove ma, if u want remove hiddens ones or telemetry or youtube, ads etc, u cannot do it.
Nevereatrice
the last i dabbled on this is redmi k20 pro debloat with ADB the used a local vpn to block ads on phone. used greenify to preserve battery life
Foetid
pm uninstall -k --user 0 *package name*
no need la, no need to use the adb, its done by canta app directly on the phone.
Use Shizuku to enable wireless adb.
just remove all ads n telemetry should see battery last much longer.
wwenze
You buy Xiaomi phone and never flash global clean rom from day one? How much ad did you see for free lol.
Foetid
i did, i change to German region and disable all the ads, mine is apac region phone, not china rom phones. My battery life still major improvement after removing all the hidden ads apps n telemetry related.
European region cannot show ads.
trento
My poco f6 buy from sg. No ads. Got 2nd app store but i don't see any ads so it doesn't bother me
ceestudent
Now the T series getting more and more expensive. Your 13T and 14T more value for money. How is the batter after 1 year? How many percent left after 1 day usage?
