- Jul 14, 2005
1. YesHi all. I got a few questions about this phone. Appreciate any answers:
1. Does hotspot work well on this phone?
2. Does it have a TRUE Always on Display that shows the time/notifications?
3. Can I use a 67W Xiaomi charger (from my Poco F5) on this phone? Will it charge at 33W?
4. Seems like some find the Essential button a nuisance because of accidental presses. Do you really find it to be a problem? Can disable?
5. Anyone tried shooting in RAW? Is there any advantage in postprocessing on desktop compared to the inbuilt software?
Also, will it feel like a downgrade from the F5? I actually like the F5, but after a recent update I get phone freezing and restarting once or twice a day. I don't know if a fix will happen, and I can't live with an unreliable device.
Also, I am thinking about moving on from MIUI/HyperOS. Video Toolbox is crippled now and I am forced to use Brave. True AOD only works allegedly on 600+ SGD devices like the Poco F7 pro and Xiaomi 15T, and I don't need something that powerful as I rarely play games. I will miss the double-click power for Flashlight though.
2. Yes
3. Yes and Yes
4. No problem for me but it is useless or me. Cannot disable
5. No, I dont shoot in raw as the camera hardware isnt that impressive either
In terms of specs and performance, definitely it is a downgrade. Have you tried factory resetting your Poco F5? See if that helps?
For me, I will still keep the Poco F5 as it is still a more capable device overall in terms of speed and performance. CMF Phone 2 Pro is using a more inferior dimensity 7300 pro, UFS 2.2. Try doing a factory reset and see if it helps before stepping onboard the CMF Phone 2 Pro.
