[Official] SingTel SIM Only Plans
1a2a3a
Happy to report that the 19.25 plan worked rather well during this morning peak hour ride 830-9. I was able to listen to radio, read news article, Reddit, received WA. Connection broke between Bishan to Braddel which require a manual trigger to restart radio. Just leaving orchard, connection went down for like 10 secs but doesn’t require manual restart (it auto connect back).
these are vast majority improvements than compared to vivifi where I could not do any one of those single item above.
mikezuper
For the 15.28 sim only plan,
Is there a way to check the 50gb free Malaysia monthly data usage stats?
is it a 5G SA plan with same speed as 5G enhanced core plan? Are standard calls routed by VoLTE or VoNR?
when is the ideal time to recontract this plan before 12 months is up? Based on terms, all the bonus data and included talk time is ceased after the contract ends
Yeah, it appears in the roaming section of the app of 0/50gb monthly as bundle:
This is what written in the app:
“Bundled Malaysia Roaming 50GB
0GB used
Expires 30 Nov”
I think it is normal 5G plan, not the priority/plus. What is SA?
0GB used
Expires 30 Nov”
You are right, just checked MySingtel app and found that as well.
We have two S$15.28 per month Singtel SIM Only lines now, one with 6GB Bundled Malaysia Roaming (earlier recontract offer), the other with 50GB (newer recontract offer).
Basically the S$15.28 per month supports 5G SA and also SingTel's "5G+" marketing terms (700 MHz band, 5G SA capable). It is not labelled as "5G+ Enhanced" and could be a bit lower priority than the plans with the label of "5G+ Enhanced".
As of now, Singtel Gomo and Singtel based MVNOs only get 5G NSA and not 5G SA. But they will get Singtel 5G SA soon as Singapore telcos are supposed to shut down 5G NSA by the end of 2025 following a directive from the Infocomm Media Development Authority (IMDA) to transition to the more advanced 5G Standalone (SA) architecture.
shawniiex
That's very interesting. Was your vivifi on 5g as well?
sansanjikikut
If that IMDA directive was to be strictly enforced, then it seems there is no purpose for the '5G Standalone' toggle in iphone mobile data settings anymore. Also seems iphone is capable of showing 5G+ symbols but just not yet in SG infra yet I guess:
Source:
https://support.apple.com/en-sg/108383
5G SA speed for singtel is around 600-700Mbps on average outdoors?
Source:
Not necessarily. It all depends on the locations.
For my testing, sometimes it is greater than 1000 Mbps, sometimes it is 200 Mbps or even lower.
Take note the S$15.28 per month Singtel SIM Only Plan does not have the label “5G+ Priority” or "5G+ Enhanced" label inside MySingtel app.
However, I do not see that the "5G+ Enhanced" plans have any better benefits than the S$15.28 per month plan.
Singtel 5G+ FAQ
https://www.singtel.com/personal/products-services/mobile/5g-plus/faq
Singtel 5G+ -->
Singtel 5G+ is the next-gen evolution of our 5G network that sets a new global standard in everyday mobile connectivity. It’s only 5G+ network in Singapore with 700MHz spectrum for the best coverage, even deep indoors.  
With increased signal strength of up to 40% in high-rise, underground and remote areas across Singapore, Singtel customers can enjoy uninterrupted calls and data services even in locations like basement carparks, HDB estates and high-rise buildings. 
The great news is if you’re on a Singtel 5G plan, you’ve already been upgraded to our 5G+ network in May. What’s more, from 25 July, all 5G+ Enhanced and 5G+ Priority mobile plans will enjoy the 5G+ Upsize with more speed, more data, more roaming and more rewards.
Network Slicing -->
It’s a sophisticated 5G technology, providing unparalleled agility, flexibility and scalability of network resources. Think of it like a having your own lane on a super highway. Network slicing is giving you a dedicated part of the 5G network that adjusts to your needs for faster speeds, better roaming and better security wherever you are.  
Singtel 5G+ Priority --> Priority Network/Roaming/Care/Security/Deals
Singtel 5G+ Priority is all about an experience that puts you FIRST:  
  • First on our 5G+ Priority Lane, always. With 4X the speed.  
  • First to detect emerging threats with advanced real-time monitoring with Mobile Protect, at no additional cost. 
  • First to enjoy this unparalleled security with Mobile Protect while you roam and 50GB Malaysia roaming for your travel wanderlust.
  • First to be served, always. Enjoy dedicated in-store, hotline & chat service. 
  • First to pre-order the latest devices. Enjoy FREE delivery, exclusive deals and 15% OFF selected mobile accessories at Singtel shops. 
Singtel 5G+ Enhanced --> Enhanced Network/Roaming/Care/Security/Deals
Singtel 5G+ Enhanced is all about enjoying the power of MORE: 
  • More coverage, more speed. Enjoy 2X faster speed, in every moment. 
  • More coverage, worldwide. Roam safely and confidently with multiple trusted network partners.
  • More support, with 24/7 hotline & chat. 
  • More peace of mind, wherever you go—with free McAfee Mobile Security.
My Singtel S$15.28 per month plan 5G+ using a Poco X7 Pro vs SingTel 5G+ Priority using an iPhone 16 Pro Max.
5G+ Priority wins.
iPhone 16 Pro Max wins.
:ROFLMAO:
sansanjikikut
I guess to have an apple to apple comparison, need to compare using the same device, day/time, location and test server for objective fairness:
  • S$15.28 5G+ plan
  • any 5G+ Enhanced plan
  • any 5G+ Priority plan
shawniiex
  • S$15.28 5G+ plan
Already compared before $15 and priority free trial. 0 difference whatsoever.
Only true benefit is during concerts/f1
