jogging and motivation thread
WussRedXLi
Wah lan, with this kind of environment and weather, i think for us to dip below 10hrs a week also difficult. :unsure: :oops:
bbbbbw
Last week my rear tyre slow leak. Went back shop and they say is faulty valve. 2 incidents in 5 weeks flat tyre lol
rarenick
I assume u r not using tubeless.
1. Is yours tpu tube? Rotate the wheel to let the valve stem upside down then dip into a small glass of water see got any bubbles around the valve and the valve stem. If have bubbles, apply super glue to seal the leak between the joining area (not on the valve itself until cannot turn the valve later).
2. If using normal butyl or latex tube, u should check your tyre very carefully. The tube take out, pump air, dunk into water to check where is leaking bubbles. Once detected, go back to position of the tyre to check for any super tiny sharp object. Sometimes even need to stretch the tyre a bit to reveal the sharp object that's stuck deep inside and become not quite visible. If too troublesome, buy a new tyre to replace to see if the tyre is the problem. The old tyre no need to throw yet. Coz if it's not tyre problem then at least can keep.
rECKleSSfElla
Dynafish xiaonian got restock for size 45 red/white colorway......my wallet is crying......
rECKleSSfElla
I listened to my wallet........decided not to get since i already bought 3 pairs of china shoes and have not even ran in any of them yet. Will also be getting a spin bike for my dad during shopee 11/11 sale so need to conserve some ammo for then.
bbbbbw
oh I using tubeless. Your point 2 is correct. The first time flat tyre there was a small sharp splint in the tyre
for the second time they said the tyre value faulty so slow leak. Thanks for explaining to me in detail 😃
WussRedXLi
Actually if you see they all, plus minus 5:00 pace (as quick as 4:34 pace maybe a bit -ve gradient), so many TCSS can shout can sing the fella can even fool around at the water station, santai easy run.....5:00 easy pace runners no lack out there.
