Yes, I will get SIMBA S$12 plan early December, before the short trip in mid-December.
Then I can compare the performance of SIMBA China roaming (26GB China Roaming, free voice roaming) with Eight S$8 plan (only 2GB roaming data but with voice roaming).
Not so sure if I want to try out Maxx S$10 plan or not. it has 3GB China roaming data but no roaming voice. Another possibility is to port Maxx to SIMBA to save S$10.
I believe I do not need to turn on Singtel ReadyRoam Asia (S$18 for 6GB China roaming). And it changes high fees for roaming voice call, so I will just disable Roaming Data for the Singtel line (can still receive free SMS).
History of China short trips previously.
1) StarHub Prepaid Roaming Data as backup
2) China mobile number plus VPN (that is the main reason I did not care about roaming previously). I used different VPN solutions including Wireguard VPN on the router to bypass the Great Firewall and it did work for short trips.
3) No need to turn on roaming on the main SingTel line.
Unfortunately my China Mobile number is longer not functioning. Now need to explore roaming.
Last week my partner & I were in Xi'an for 7 days - both on SIMBA's Senior Plan. I'd 0.21GB balance after the trip; partner's was 0.99GB balance - I didn't surf as much as when I'm in SG though.
I'd another SIMBA's PrePaid $12 with 18GB for China etc which I gave to a friend, on the same tour, to use - she used nearly 4GB.
Most times we were allocated 4G by CTC (I presume China Telecom). 99.9% was good, only on one occasion all SIMBA's subscribers on tour had no signals, even trying airplane mode on/off, change APN, on/off phone, manual choosing other Telcos (which was rejected) etc.
Finally it worked by switching in phone's settings (Preferred Network Type) to focus on 4G without option for 5G. It was only a small hiccup. Much later when I switched back to have Auto 5G the issue didn't arise again
Signal coverage was very good, whether high up in the hills, deep down in the vallies, deep undergrounds, highways etc...
Added:
Didn't use hotel WiFi at all as Google, Whatsapp etc cannot be accessed.
