M1 Mobile discussion thread
Lonelyoldman80
Just now was at woodlands basement interchange testing my new m1 plan while waiting for my bus home, was really surprised to see that i have full bars 5g reception .. previously was using starhub and singtel priority plan only can get 1 bar 4g signal only ..
nnmn732
Anyone here recently few weeks M1 5G like feel very choppy?????
Yes! My wife got stuck in building lobby where was going to do medical because couldn't access the reception's guest sign in website. I've also been having to do airplane mode to reset the network connection a few times in past 2 weeks.
Been on M1 for almost 4yrs no problem but now im taking a look at Singtel and tempted even if more expensive.
Jurong640
You can consider Singtel MVNO like Zym or Zero1, don't need to go with Singtel. Using same ST network at $15/mth, free 6 months sub too, effectively $7.50/mth. Comes with roaming data and 5G too
A7997A
While this is clearly an issue with m1, i would also have an issue with their operation that has no manual fallback. What a world are we living in?
ragnarok95
Senior Moderator
Senior Moderator
I will have to stick to M1 for the next 6 months cos i just got the apple watch and M1 mobile share have free 6 months lol.
Next 6 months you guys will have to listen to my complaints..... unless M1 buck up.
Jurong640
It's okay, I will just summon the M1 A380 plane everytime it happens. After the plane is being sent away, signal will be better
camoguysg
Did anyone notice the 5G signal seems to be very weak these few days? At home I used to get strong 5g signals but for past few days I keep getting 4g and 4g+ only.
