Thought of running a router with N100 but wife will scold if I buy another boxProxmox VE itself is not really for daily driver but rather the platform to run VMs and containers. It has a nice Web UI. Usually you run it headless (without monitor, keyboard and mouse, other than initial setup).
For PVE setup with N100 CPU based mini PCs, I will not want to run Virtualized Windows, but no issues to run Virtualized Linux VMs if you have enough RAM (say 16GB).
For faster CPUs and with 32 GB RAM, like your Ryzen 7 7840HS Mini PC, indeed you can run Virtualized Windows and Linux VMs and use the VMs as daily driver. The client can be a slower laptop since the VMs run on the faster machine.
so small she wont know or notice one, if u hide it properly lolThought of running a router with N100 but wife will scold if I buy another box![]()
Wow, really very smallEspecially smaller ones from iCoolCore, for example, R2 model, with quad 2.5Gbe ports.
https://www.ikoolcore.com/
I tech refresh my desktop part by part to avoid suspicionThought of running a router with N100 but wife will scold if I buy another box![]()
Hi, mind sharing how did you get HWZ $20 off? I think I googled and the code didn't seem to be applicable.No share link, I just post direct hyperlink can? 15% off still have leh.
https://amzn.asia/d/5kBxOyl
You can either use HWZ $20 off, Citi $12 off or $15 Unionpay to offset the price.
early order still can use, now should be used up already since limited to 1000 only. Maybe friday will refresh again, fingers crossedHi, mind sharing how did you get HWZ $20 off? I think I googled and the code didn't seem to be applicable.
Also did you install a 2nd SSD into the 2nd NVME slot? Any recommendations on which ones to go with. I'm considering getting this as a 2nd mini PC (really love my current beelink Ser6 Pro) but this price is too good to resist and I could use my old one as a media/torrent/work machine and use this for my emu/light gaming needs.
Also what do you normally use it for?
I grabbed the voucher on the second day.Hi, mind sharing how did you get HWZ $20 off? I think I googled and the code didn't seem to be applicable.
I see. what SSD did you go with? Looking to grab maybe a 2-4TB SSD to slot into the 2nd slot to install my stuff.I grabbed the voucher on the second day.
1TB SSD not here yet.
I use it for office work to replace my 10 year old Intel I7.
Other than all the USB slots are flipped, the box runs fast even if I disable turbo and fix it at quiet mode.
Don't game.
tiagong be200 not compatible with amd, need to get mediatek mt7925 or qualcomm wifi card.Using a beelink ser8 for about a year. Thinking to upgrade the wifi card to wifi 7 but not sure if it's possible with something like these
BE200 WiFi 7 Card | M.2 PCIe WiFi Card | Tri-Band 2.4/5/6 GHz | Up to 5.8 Gbps | Gaming WiFi Card for PC | Supports Bluetooth 5.4 & Intel PCs with Windows 10/11 | BE200NGW
TP-Link Archer TBE400E PCIe WiFi Card BE6500Mbps WiFi 7
most budget mini pc may struggle with 1080p gamingHello bros, would like to seek recommendations as my GPU died. Am looking to get a mini PC to use for next 9 months before my next PC overhaul. Office work, light gaming on 1080p screen. After which will hand down to kids for pri sch use/stream show to tv
Can you recommend smth?
you can't. need pcie slot.Using a beelink ser8 for about a year. Thinking to upgrade the wifi card to wifi 7 but not sure if it's possible with something like these
Requested, however beelink CS says that the upgrade kit only supports the original wifi card.you can't. need pcie slot.
check out from beelink forum. free upgrade of ser8 antenna.
based on this image from a review:you can't. need pcie slot.
