Charlie_Zhan
- Nov 17, 2013
zero1 cs pangkang liao.. my line still cannot make outgoing calls
What phone are you using?zero1 cs pangkang liao.. my line still cannot make outgoing calls![]()
Omg that bad ?!zero1 cs pangkang liao.. my line still cannot make outgoing calls![]()
haha already mentioned that in a previous reply to you :I emailed them and they said porting quota is full . Don’t know got such things one
But quota delay usually is 1 day, esp for mid week port.The actually cut-off time is not stated by most telcos, and each could have a different cut off time.
Vivifi did mention something like 6pm or 6:30pm, but by any measure, by the time you posted that message it should be too late for tonight.
Also there is a matter of quota, if quota is full for the day, even if you are within cut off it will be delayed to the next work day.
Maxx can port out in base mode.My m1 Maxx actual renewal is on 3rd Dec. So I’m taking it in the view where if this continues to delay , at least my already-paid use for M1 Max is still running and I didn’t waste it
Wow there is an end of month peak? I’m sorry I didn’t knowhaha already mentioned that in a previous reply to you :
I suspect you also kenna the end of month peak, esp with the promotion supposedly ending this month.
Those on calendar month billing will usually port out around now.
Yes end of month is the time those on Calendar month billing port out to minimize wastage.Wow there is an end of month peak? I’m sorry I didn’t know
Oh!!! Then how long does it takes to clear ?Yes end of month is the time those on Calendar month billing port out to minimize wastage.
But more importantly this time it coincide with the "end of promotion" for 6 months free, so that creates another peak. We saw that end of Oct when the promo was supposed to be ending.
Typical suggestion is go to sleep and check tommorrow morning.Port-in issue.. previous telco (eight) signal gone, pop in zero1 SIM card and no signal after restart phone.
How long do you guys wait for the zero1 signal up on phone?
Someone mentioned that he got an email saying porting is submitted around 3 workdays after ordering via esim. Have you received that ? If not It could be early or even mid next week before porting occurs, given that there seems to be a surge of porting request.Moving from M1 to Zero1 and receive confirmation of my plan purchase on 26 Nov, 2pm and received my eSIM details within the hour. But until now have yet to port in and still getting M1 signal.
Thanks a lot, got the signal at 2am. Eight mobile switch off signal at 11.30pm. 2 hours plus of no connectivity.Typical suggestion is go to sleep and check tommorrow morning.
But usually should get signal something between 1-2am.
That is just signal, don't expect full operation.
Basic operation should work by 7am, 5G by 10am.
What's the status of your plan? Is it still "pending" ?Thanks a lot, got the signal at 2am. Eight mobile switch off signal at 11.30pm. 2 hours plus of no connectivity.
I’m on streamo bold plan which gives 12gb ap roaming but on the zero1 app, under usage tab, it shows only 5gb ap roaming, is it just UI bug?
ifengWhat phone are you using?
Try to remove your SIM card, do a restart of your phone, and aeroplane mode. APN set to e-ideas, singtel (postpaid)
Eight been deactivatedPort-in issue.. previous telco (eight) signal gone, pop in zero1 SIM card and no signal after restart phone.
I activated my zero 1 sim on Wednesday and today is Saturday . I am still stuck on m1 Maxx and zero1 said the donor telco has quota , hence the delay
thankfully this is my secondary line which I use for my yoga and ballet lessons . Imagine if this is main line. I will be out of actions for days if M1 Max to zero 1 porting has a long gap
few months back, circles life also have this "issue", "delayed porting".Means M1 Maxx has quota to port out? Interesting.
