OnePlus 15 series
Bweebweee
you are talking about S26 or S26 Ultra? The base variant rumour don't look good, no much upgrades. Only the Ultra have some minor upgrades, like 5200 mah battery and 60W charging, camera no much changes.
5200 battery and 60w charging is all the upgrades ah.. that kinda sucks
royfrosty
Year on year the rumors are always certain and affirmative from the leakers. By now you should be able to see what they are up to already.
Forget about s26 line up. They not gonna bring in any new cutting edge technology. At best they might just wanna reuse some sensors, give you minor improvements on the cam. And some in build privacy screen. Other than that nothing much will change.
Jurong640
At this juncture, It's quite embarrassing if Samsung is still offering less than 6000mah battery for their flagship series.
i won't care much about battery size if they optimise well and fast charging. But it's the camera lens i cannot take it. it is using same old lens and sensor since 2021
royfrosty
It's already less than that as mentioned in so many trusted leakers. The refusal to move on to sil carbon battery is just mind boggling. Good luck to them.
And the cameras. They are just doing a minor upgrade on the main cam. 200MP with f/1.4 as compared to the predecessor f/1.7. And the rest of the rear cams are likely gonna use the same old camera.
BBQ99
I am more concern about Samy Green/pink line issue. I though it is only old batches amoled issue. But i just have a friend with Fold 7 line issue on the outer screen and 1 shot 2 green 1 pink.
Lucky warranty still haven't end.
Just this i avoid especially only 1 year warranty and no extended support for this issue.
Jurong640
Huh? New Fold7 also got the issue?
BBQ99
Yup i am also suprised. But my friend also did not know what happen and is not sure he knocked the phone or not. He admitted he drop the phone before(got case so no physical damage) the line occurred quite sometime after dropping.
I think over 1 mth after repair. No issue till now.
Maybe he is just unlucky. I know of S24 Ultra 2 years old no issue. But my 2 OP phone gana before so i paranoid now since OP8T and 11 both used Samy Amoled.
Pryson
Any OnePlus 13R upgraded user to 15 here? Contemplating whether to upgrade anot. lol
dredd
anyone experiencing Double Tap to sleep when the phone screen is on?
I have no issues to wake the screen by double tap on standby mode though....
found the setting
it's now called "double tap empty space to lock screen"
Read HWZ Forum Rules!
