- Mar 22, 2011
can call, but stand by for exorbitant bills. Just avoid if possible. If you got a second line, get simba or eight, can use IDD calls.By the way go overseas cannot call right ?
Okay I have eight as backup . Will bring eight with me . What if when I’m in Malaysia and someone calls me , I don’t pickup will it charge me?can call, but stand by for exorbitant bills. Just avoid if possible. If you got a second line, get simba or eight, can use IDD calls.
hmm, is it possible to activate call divert (all calls) to your eight number and switch off the zero1 line before going overseas? then the "call divert" will just be normal Spore call mins usage and not international roaming calls?Okay I have eight as backup . Will bring eight with me . What if when I’m in Malaysia and someone calls me , I don’t pickup will it charge me?
I have receive the same by zero 1 that I have successfully deactivated international calling though
I’m using iPhone 17 pro max that has my zero1hmm, is it possible to activate call divert (all calls) to your eight number and switch off the zero1 line before going overseas? then the "call divert" will just be normal Spore call mins usage and not international roaming calls?
hmm, for iphone, go to "Settings", under the Search box at the bottom, type "call forwarding" and activate it - type your eight numberI’m using iPhone 17 pro max that has my zero1
my eight is inside the honor 400 lite
how do I do the call divert ?
Oh I found it ^^ thank youhmm, for iphone, go to "Settings", under the Search box at the bottom, type "call forwarding" and activate it - type your eight number
Go to your zero1 app - > account - > service management, scroll down, look for international roaming calls & SMS.By the way go overseas cannot call right ?
Yes the blocking for Int calls and sms are activatedGo to your zero1 app - > account - > service management, scroll down, look for international roaming calls & SMS.
Is it activated?
lolz no need to report your whereabouts in the forum to us !Now at Dona bakery JB
Better than verbena ?Now at Dona bakery JB
turn off call screening and live voicemail on your iphone when you are overseas.Okay I have eight as backup . Will bring eight with me . What if when I’m in Malaysia and someone calls me , I don’t pickup will it charge me?
If I understand it correctly, iPhone live voicemail is different from regular telco voicemail.This may still incur high charges if the following Singtel FAQ is still applicable.
https://cdn1.singteldigital.com/con...ts-services/mobile/add-ons/VM_General_FAQ.pdf
Are there any charges for VoiceMail?
Airtime charges apply when:
• You are accessing your VoiceMail mailbox and retrieving your voice messages.
• Your caller starts hearing the VoiceMail announcement until he/she finishes depositing a voice message. (Note: the caller is also charged airtime).
• You utilise the Call Return feature and is connected to your recipient or is diverted to your recipient's VoiceMail mailbox.
Roaming charges apply when:
• You access and retrieve your voice messages from overseas.
• Your callers leave you a voice message when you are overseas.
Call Forward:
• You will be charged standard outgoing airtime charges for a missed call diverted to your VoiceMail.
You are right, @twosix told me this previously it is a iPhone new featureIf I understand it correctly, iPhone live voicemail is different from regular telco voicemail.
For call forwarding, that is the reason why one should divert all calls (unconditional, before forwarding the call to roaming partner) instead of divert missed call (conditional, after forwarding the call to roaming partner).
There is a major difference between the 2.
im referring to the live voicemail feature on iPhones.. not telco.. and ST MVNO dont have voicemail service in the first place.This may still incur high charges if the following Singtel FAQ is still applicable.
Call Forward:
Will incur call time as well. Turn this off when roaming unless using simba line.You are right, @twosix told me this previously it is a iPhone new feature
The main new iPhone voicemail feature is Live Voicemail, which transcribes voicemails in real-time as the caller speaks, allowing you to see what they're saying as they leave the message. You can choose to answer the call while it's in progress, and the feature can be turned on or off in the iPhone's settings under Settings > Phone > Live Voicemail. This works with iOS 17 and later, and can also be synced to iCloud.
Looks like it just uses data to record / listens
