Zero1 Mobile discussion thread
sango65
On hindsight my battery just drop 14% the whole day
So your Zero1 line is now switched off in Msia? Have you tried to ask someone to call your Zero1 number and will be diverted to your eight number?
cherynsq
I use my zero1 data roaming over there . Thankfully yesterday I follow your advice and setup call forwarding
today calls were forwarded
Lynxlok94
Wah sien when are they launching 5G+?
I wanna port in but don't wanna risk having to go sim swap later in case they somehow give a non 5G SA sim (I know they say new users supposed to get compatible already but still)
gapboy
Port in now will get a new 5g SIM card, no need to worry.
AMD_Duron
Just port. They have been issuing for a while now since the announcement.
Still no 5G+ as of 09 Dec 2025. :cautious:
Zero speed in implementation! :cautious:
I don't think the issues are with SingTel MVNOs, rather it is controlled by SingTel.
FYI, I checked recently, SingTel Prepaid 5G is also only with 5G NSA. I bought the S$15 hi! 5G+ SIM card recently.
https://www.singtel.com/personal/products-services/mobile/hi
https://www.singtel.com/personal/products-services/mobile/prepaid-plans
SingTel has on-going roadshows to replace existing Prepaid SIM Cards to 5G+ SIM Cards in preparation for the 5G SA deployment.
And it is the same for Gomo as per the reports.
poland_ball
If I understand it correctly, iPhone live voicemail is different from regular telco voicemail.
For call forwarding, that is the reason why one should divert all calls (unconditional, before the call reach the roaming partner) instead of divert missed call (conditional, after the call reached the roaming partner).
There is a major difference between the 2.
Err this one I tried before, diverting all calls while I was overseas. Apparently how divert works is your phone calls the diverted number, so you will still incur roaming charges as long as your SIM is registered to a foreign network. Learnt it the hard way. Got charged quite a lot still :(
However, I'm not sure what happens if your sim is off and not connected to any foreign network. In that case diverting all calls may still work
Synnexo
My understanding is that with iPhone Live Voicemail, the phone itself answers the call and starts transcribing it in real time. So if you’re roaming, this should count as a roaming incoming call.
For regular voicemail, your line actually “calls” the voicemail system to deposit the message, so that part should be considered a roaming outgoing call.
If you’re diverting all calls to another number, e.g., an Eight number, then the primary SIM should not be registered / connected to a roaming network. If not, roaming charges will apply.
