3/4 as it thicker but insulation cannot squeeze, if no space then 1/2My toilet always have some form of condensation. Is it better to get armaflex shield cx1/2 inch or class 0 3/4 inch?
Wtf so cheapHooted a Panasonic X-inverter system 1 at $343 with replacement service from S Z Aircon Pte Ltd on Shopee after deduction of $400 climate voucher... hope all goes well...
you nv say which model but based on the pdf i guessing scm40ys or 27k btuI m planning to buy this system 4 3x12kbtu 1x24kbtu to replace the Panasonic one for my re-sale EA. hope to have u guys inputs and advice what I should look out for especially those with experience with this model or manufacturer.
the contractor offers the following materials for the piping and trunking
16mm pvc drainage
class 0 armaflex 3/8 n 5/8 thickness insulation for 21swg copper pipe (made in Thailand/Malaysia)
4 core wires 4c40 & 3c70 (made in singapore)
https://coolserve.com/wp-content/up...i-Heavy-Industries-Rocket-series-2025-NEW.pdf
thanks for ur insights! yea, I actually prefer spending more now for a system that is more lasting. but this model if I m not wrong just debut in jul so am relying on brand name for confidenceyou nv say which model but based on the pdf i guessing scm40ys or 27k btu
since you only got 27k btu, you have to know which room need to on ac as you cant on them all at the same time
there a few idea here.
- some prefer to have more btu then needed so it AC last much longer
- some prefer just right (right type of btu, right temp 24c to 27c) and dont feel the need to have lot of btu as once set temp is reach, the extra btu is not needed
- some view and plan ac as in planned obsolescence cause feel thing are not as lasting as last time, mean focus is $$$$
there no wrong or right. spoil or last long is heng or suay.thanks for ur insights! yea, I actually prefer spending more now for a system that is more lasting. but this model if I m not wrong just debut in jul so am relying on brand name for confidence
yes it is the scm40ys-w, 3xSRK13YYS + 1XSRK24YYS, they claim free upgrade from 9btu to 12btu for all fcus so I just took it up. 24btu one is for the living room with top up of $150
I compared it to the equivalent starmex n daikin seems to be about the same in terms of cooling performance and functions wise. am also drawn to the better looking fcus n wifi control...aghh so many things to consider. guess I'm getting u guys insights to correct my sense of priority haha
the question is if it spoil, are you going to repair or replace base on your choice
my company midea system 1 i think this yr 5 or 7yr liao. still working even when it hardly service
Use a few AI since it free.yes that's y I top up for the extended warranty
I pull the figures to chatgpt to analyse n compare their performance, are they even accurate?
Your exact configurations:
Mitsubishi Heavy SCM80YS (3 × SRK13YYS + 1 × SRK24YYS)
- Bedrooms each receive 1.67 kW
- Master receives 3.03 kW
- Total: 8.0 kW (max 8.0)
- Min input: 0.4 kW
- Known for stable humidity removal & dry coil designs
Daikin MKM85ZVMG (CTKM25 + CTKM25 + CTKM25 + CTKM71)
- Bedrooms each receive 1.27 kW
- Master receives 3.59 kW
- Total: 7.4 kW (max 10.24)
- Min input: 0.27 kW
- Known for lowest energy use and strong master-room performance
Most people overfocus on BTU.
2. What REALLY matters for a Singapore home
The truth is: the delivered capacity per room + humidity control performance is what determines:
Below is the breakdown by real-life concerns.
- comfort
- skin dryness
- mould growth
- electricity bills
- air quality
- night-time sleep quality
3. Skin Sensitivity
✔ Winner: Mitsubishi Heavy SCM80YS
Why?
- Higher delivered capacity in bedrooms (1.67 vs 1.27 kW)
- Faster pull-down → shorter periods of over-blowing cold air on skin
- Less aggressive prolonged cooling needed
- More balanced coil temperature → avoids over-drying
- Better humidity extraction
MHI systems typically run:
- colder indoor coil
- longer coil-contact time
- more stable airflow
This means lower dewpoint and reduced skin stickiness, but not excessive dryness.- Compressor stability
SCM40YS uses a very conservative compressor ramp-up curve
→ avoids sudden blasts of super-cold dry air that irritate eczema.- Finer airflow control on SRK series
- more gentle swing pattern
- smoother fan transitions
Excellent for people whose skin reacts to drafts.
4. Mould Prevention & Humidity Control
✔ Overall Winner: Mitsubishi Heavy SCM80YS
Because mould is a humidity problem, not a BTU problem.
Why MHI wins:
(1) Stronger bedroom dehumidification
Higher delivered cooling capacity =
faster humidity pull-down, especially in smaller rooms.
(2) More stable compressor speed
Stable coil temperature =
more reliable dew formation on coil =
better moisture removal.
(3) SRK indoor units have:
- large heat exchanger surface
- better refrigerant distribution
- slower fan minimum speed
These are ideal for mould suppression.(4) Daikin’s main weakness
Daikin multi-systems are optimised for efficiency →
They often run warmer indoor coils to save energy.
This results in:
slower humidity removal
more “still damp” feeling
higher mould risk on walls, wardrobes, leather bags, mattresses
5. Overnight Bedroom-Only Use (Real Singapore Scenario)
✔ Winner: Daikin for electricity
✔ Winner: MHI for comfort, dryness, mould control
If running only 1–2 bedrooms:
Daikin strength
- lowest minimum compressor load (0.27 kW)
- lowest electricity draw
- excellent whole-night efficiency
Daikin weakness
Because its minimum load is LOW, the system tends to:
- run the compressor warm
- reduce condensate formation
- humidity creeps back up after 2–3 hours
- airflow stays “dry but not dehumidified” → bad for eczema
MHI strength
Even with higher min load (0.4 kW), MHI maintains:
- colder coils
- better condensation
- stable humidity at 70–75% RH down to 55–60% depending on setpoint
This is the ideal RH range for skin comfort and mould prevention.
6. Cooling Performance by Room Type
Bedrooms (small rooms)
✔ MHI wins
- more cooling power in small volumes
- faster drop in humidity
- quicker achievement of steady, gentle airflow
- ideal for sleeping comfort
Master Room (largest room)
✔ Daikin wins
- 3.59 kW delivered
- better for large open spaces
- better if master room west-facing, afternoon sun, or large windows
7. Air Cleanliness & Coil Hygiene
Mitsubishi Heavy
✔ Best coil cleanliness in real use
- hydrophilic coil surfaces
- stable coil temps → less condensation cycling → less slime
- more logical fan-dry mode
Daikin
✔ Good filters
⚠ Coil tends to run warmer → condensation cycles can cause musty smell faster if maintenance is delayed.
8. Compressor & Reliability Considerations
Mitsubishi Heavy
✔ Overbuilt compressors
✔ Very stable current draw
✔ Minimal surges
✔ Runs cooler internally
→ long lifespan, especially in Singapore humidity
→ fewer PCB failures
Daikin
✔ Excellent efficiency
⚠ Higher surge current (up to 14.5A)
⚠ More sensitive to distribution imbalance
⚠ Maintenance-sensitive to keep efficiency high
9. Electricity Cost
With your usage (3 bedrooms regularly):
- Daikin uses about 10–18% less electricity
- MHI provides better humidity and comfort at slightly higher cost
Won't go wrong with Daikin or Mitsubishi Electric. Each has their own strengths.thanks for ur insights! yea, I actually prefer spending more now for a system that is more lasting. but this model if I m not wrong just debut in jul so am relying on brand name for confidence
Sharing what i know and learn so far, i try make it in point form to keep it simple:
contact 4 company:
letscool
amyth
aircon rescue
newway
my shortlist are simple:
look at google bad review (or any other source) only, the bad review date last posted how often bad review is posted
materials
materials :
letscool quote me : SWG22
amyth quote me : SWG22
aircon rescue quote me : SWG21
newway quote me : SWG21
the price all 4 are less then $40 different
all other almost the same of 1/2inch, copper wire almost same core and number of wire etc..... so my shortlisted are aircon rescue and newway as they quote me the correct materials (i started a thread talking about the copper thickness)
i choose newway based on google (or any other source) bad review feedback or lack of (as explain) aircon rescue no cause not much of any feedback from any source (it a new company)
after the piping is 80% done, i go take picture . i take this drain pipe like very little insulation when he saw me take picture he redo (or maybe he already want to redo i dont know) but happy he did redo cause the next 3 to 4hr doing the piping from 3.30pm until 6.30 to 7pm++++++
more checking, so far so good after that strange redo
from here on, all is good, everything is good, dont even need to open mouth liao
drain pipe no join connector but using heat to pipe and install with insulation at blend area
video about layout(before drain pipe redo), vacuum and doing the soap test to check leak , installer auto use soap to check for leak on their own unlike my first installer who dont even vacuum and do the soap test
video link:
https ://imgur. com/7fYCGkg
https ://i.imgur. com /7fYCGkg. mp4
last step, they even add rubber on the condenser leg, (this is not needed at all, some may first it a cons if the rubber wear out) i feel adding it, doing the soap test show their professionalism
workmanship issues take time to show up, can be weeks to year. but so far everything look good for now
This is for family member which I help overseeThis is your 2nd air con installation? I remember 1-2 years back you just installed your air con system.
the only one that does all the above you mention are own ppl do for own family member or very close family membersI've read about newly installed AC units lines being vacuum by their contractor. This, I believed, is a step in the correct direction for any home AC installation locally or in this region (rather than purging AC lines with gas).
But in my opinion, vacuuming alone without leak test does not fully fulfill it's purpose. A micron meter should be use to monitor the vacuum in the line (some say pressure gauge should be sufficient with the in hg readings). Then make sure the readings stabilize after the pump is switch off to detect any vacuum leak for about 30mins. Soap water to be use for leak test as well, especially at the joints area, to detect visible leakage apart from reading the micron meter.
Additionally, prior in vacuuming step process, the lines should be filled with N2 and pressure tested at 200 psi at least to detect for high pressure leak for a few minutes. Same soap test to be done at the joints as well.
My point being, does any contractor here in SG does the below steps process?
1) Installation of compressor and AC lines
2) Fixed lines to FCU.
3) Filled line with N2, positive pressure test.
4) Discharge N2, vacuum line using Micron meter, vacuum leak test.
5) Filled up the lines with refrigerant by opening the valve at compressor side.
6) FCU testing to check the coldness, top up gas if necessary.
Step 3 and 4 usually omitted by contractor in place of gas purging, still quite common. But recently, step 4 is done by vacuuming the lines without monitoring the vacuum level or leaks. So if there's a leakage, gas will leak n air will still contaminate the lines. That's why some of us, our Aircon will not be cold within weeks, months or couple of years.
Sorry for the long post need to say the above. Still looking for a contractor that does the above steps as standard practice.
