Zero1 Mobile discussion thread
sango65
oh, you finally comment.
So the golden question is, do you kena voice call roaming charges when your zero1 line is used for data roaming and someone call your zero1 number which is force diverted to your spare Eight number?
@cherynsq, would you mind share a screenshot of your zero1 app if you have any voice call roaming charges in your recent Msia trip? So that we are certain there wont be any charges when zero1 number is force diverted to spare Eight number? Thanks!
TyL3r_DuRd3n
in your router setting, did you enable wifi 7 (6ghz)?
yup, only 6GHz can hit this speed of 1.4Gbps.
5GHz around 800Mbps nia.
enable 6ghz and MLO also no use.. iPhone 15PM doesnt have wifi7. :crazy:
can connect to 6GHz, but need to manually join. pui pui pui manually join every single time i come home :s15: :s15: :s15: :s15: :s15: :s15: :s15:
Jurong640
Zero1 Speedtest
TP-Link Be805 speedtest
beng035
For mobile phones let say iPhone . What’s the top speed it can achieve ?
with router HB710, in line of sight using wifi
IP14PM - approx 400mbps down with 5g, 80hz
IP16PM - approx 1300mbps with 6g, 160hz
i reckon this speed very good liao for everyday use.
even if you have the perfect setup, you will not get the perfect speed also.
TyL3r_DuRd3n
a n00b question
Which n zero1 or singtel MVNOs will use ?
5G NR: n1/n2/n3/n5/n7/n8/n12/n20/n26/n28/n38/n40/n41/n66/n77/n78
