Wait. What do you mean by True 5G SA next year? Isn't Singtel MNO already on 5G SA?iOS 26.2 support VoNR for Singtel and it's MVNO users, remember to turn it on to prepare for true 5G SA experience next year.
Okay. So now is True SA?VoNR, voice using 5G SA network.
Previously 5G SA only for data connection. Voice is still using VoLTE or VoWiFi, not using 5G network.
M1 already have selection for Voice over 5G standalone.VoNR, voice using 5G SA network.
Hi,
Currently, I have 4 ST mobile lines(contract ending in 2 days). If I apply for the SOP $15.28 for all the 4 lines through the link. What is the likelihood that Singtel will approve all the 4 lines(all lines under the same name)?
Hi,
That will be best. Does it matters if 3 of the lines are currently mobileshare lines? From your experience, how soon do you get the reply from them?Very likely they will approve all four.
Not so sure about mobileshare lines. But I tend to believe they will still approve.That will be best. Does it matters if 3 of the lines are currently mobileshare lines? From your experience, how soon do you get the reply from them?
I'll put in my applications on the 18 Dec(last day of contract).Not so sure about mobileshare lines. But I tend to believe they will still approve.
They will reply within three working days by sending your the service agreement through email.
My feeling is mobileshare lines won't be approved.That will be best. Does it matters if 3 of the lines are currently mobileshare lines? From your experience, how soon do you get the reply from them?
Logically it's an upgrade from MobileShare to SOP plan thus, should be accepted.Hi,
I converted two of my mobileshare line that are still within contract to the $15.28 sim only plan without issue.
it is still considered as ‘upgrade’ in a way.
IMHO.What will be the current best solution for me as I am looking for a sim card/ Esim to provide me with a second phone number to create new accounts like telegram/we chat that requires number verification.
No data,talktime etc required, just number for verification, receive OTP.
Looking at the above scenario, does it mean that when we want to receive calls and text on our roaming Singtel line, we've to turn on DATA ROAMING even when ROAMING DATA is set from another line?Hi all. I have the $15.xx Singtel plan (SIM 1) and $8 Eight plan (SIM 2). SIM 1 data roaming off. SIM 2 data roaming ON. Im in Philippines now and cannot receive SMS/OTP on SIM 1. Why?
Solved:
Found out DATA ROAMING (NETWORK) in Singtel app was OFF. Switching it ON solved the problem.
I'm playing with the thought of porting a line to eventually sit on the $15.28 plan, since Maxx 5G is minimum $12 now. It's going to be a supporting line for Simba in same iPhone.Then it is an okay choice. Caller ID is free.
Some other users choose to go with Enhanced Core at S$40 for one month, then recontract to the S$15.28 plan (12 months contract).
