Stable diffusion thread
x1243x
How many times do they regenerate the prompt to get each frame right and consistent.. that they did not twll you
doesn't matter. they have the good hardware and software.. so the generation time is a lot faster
BlackWing1977
I personally gave up trying to run any models locally. It has gotten like bitcoin mining last time. Too slow, even though it's good to bypass censors.
I still keep a old copy of Amuse installed that have the censor bypass... later version all have the censor...
AikiBoy
Sideline abit... this local YT channel is crazy. Views are in million..
Look thru some... i admit beside graphic, i duno what this channel about. Lol
doogyhatts
The channel is non-monetised because the content is targeted at children.
doogyhatts
Wao i search the youtube monetise website. It say per vid estimates generate 75k USD. If monetise, the channel owner huat big
The owner of the channel can monetise it in the future, because the targeted children have all grown up to 18+.
But he needs to make new content that is not for children.
V-FORTY
@doogyhatts have you tried using webtools for your videos generation? some webtools are quite impressive. able to combine scenes into fluid videos. or is the quality of webtools too low?
doogyhatts
I am using KlingAI right now. They have both the web-browser and desktop application.
I did also use Sora2, but only for their multi-shot storytelling solution.
Sora2 outputs 352p resolution at free tier, so I still have to use Z-Image-Turbo and Wan2.2 to upscale the keyframes.
After which, I use the images at 1080p resolution in KlingAI, using either video-2.6 or video-O1 model.
Additional shots can be made from Kling Lab, which has Nano-banana-pro. I use it to make my character sheets.
The overall quality has reached cinematic realism, depends on the model.
Luma's Ray3 is expensive, but that's because those are from the US.
AikiBoy
Sora2 is the old or new one?
doogyhatts
Open-source can now do cinematic hard-cuts similar to Sora-2 (without the audio).
He used a 4080 to do this.
doogyhatts
but only can start with first frame right? cant use middle or last frames.
Yes.
The input frame is likely to be a medium shot, that shows the upper body of the person and the table.
But notice that the table is slightly different later on.
Then again, I am not exactly sure what his input image is, but the whole process is more like reference-to-video.
So I wonder if it can input a large 2x2 image.
Btw, if there are new standards in AI short-film production, I will post on the other thread.
This one is the new standard for doing WoW-based storytelling content using AI tools/models.
https://forums.hardwarezone.com.sg/...beedeo-sound-kong-chio.7130521/post-158172829
