hyperfuse
- Sep 23, 2019
Thanks for the reply. Appreciate it.I bought an EB810v before to try as a mesh node on my Singtel broadband. Worked fine, but seeing so many complaints about it, glad I sold it off.
You’re better off getting Singtel’s HB810 equivalent, where firmware updates are more frequent and you can download the firmware from Singtel unlike Starhub’s EB810v where you can only depend on Starhub to push down the firmware.
Question for u.
Which will U do in my use case scenario?
1)Just get the M1 bundled BE805 as main router and use a switch
2) get the Singtel hb810v as main router
I basically have another router in my MBR that will run in ap mode or via ethernet backhaul in mesh mode and it will be connected via ethernet backhaul to the main router 1 x 10g Lan port. The other 1x 10g wan port on main router is for connection to ONT. So for my desktop that I am using ethernet, if I am using be805, I will be capping It to 1gb since the be805 Lan ports are all 1gb.
That's the reason why I thought of using the one from starhub or Singtel since the Lan ports of those are 2.5g.
So for my use case which will U go for? Be805 with a switch or HB810V and can do away with a switch
*Btw I already bought a tp link 10g 5 port switch. The sx105. However, heard ppl say running hot etc, and also my pc network card is only max at 2.5g anyway. So I might just sell that switch away since it's still sealed and bought locally
