wutawa
- Jan 25, 2003
dbs definitely has much higher yield than mii. just like there r many stocks that perform better than dbs.MariInvest you can really lose a lot if the market turn. Eg July 2021 it was at 11.40
Oct 2023 it was at 9.28
Tell it to those who really hold long they'll see it in negative light. For those who bought at 11-ish. MariInvest is very much like stock market. Just that it issue out dividend monthly. Eg if you own DBS, it gives you dividends quarterly. But DBS goes up over time up to today. So if compare DBS to Mariinvest over the past years, DBS seems to perform better. I raise this up to help you see better why I think Mariinvest is very much like stock market.
those bought mii at $11.40 may be under big loss in 2023 but still profit now if consider the payouts. however, the $9.57 can be the next $11.40.
although misp is more liquid than mii, and misp seems less risky. if u look a bit deeper, it is actually reverse.on the surface, 360 is capital and int guaranteed while mii isnt. if u look a bit deeper, it is actually reverse. hehe
