Xiaomi 15 Series
frizee
I logged in with another account seems to be able to get it for the 15tpro.
btw... based on user experience is 15tpro superior to 15 non pro ? or should I save it and get past year model? tks
Ya 15T cannot, only pro lol not sure why
never used T series before bro so im not sure :ROFLMAO:
Shadowz1984
It depends on your needs. Pro has better chipset. Day to day use shouldn't see much difference, just that Pro will be more smooth. If gaming, better to get pro. Also pro has better camera. But if you don't really care much about photos, then T should be good enough. You can go any xiaomi store to try out and see for yourself. Ultimately it's you who will be using the phone, so you need to try for yourself.
dev_stg_prd
tks for the advance.. I think likely I'd get the 15t pro due to the cam.
limjialok
Anyone knows when would 15t price decrease into the $400+ range? I recall it happening quite soon for 14t series
Sendai
Hi, looking into 15 ultra version china set as 17 ultra seems like not much upgrade and size seems bigger for 17 ultra. Is there any issue of notifications and apps, bank, singpass reset back to default even after we activate the necessary for notification?
Shadowz1984
How much is the 15 ultra china set? Might be better just get local sets when they launched the 17 ultra.
dev_stg_prd
phone reached last week, today only got some time to setup.
full charge then need to patch twice.
btw.. any tips on settings wise?
also I didn't use the app to port from another phone.
I manual do it
dreamcast18
I manual do it
disable the ads and recommendations.
dev_stg_prd
which you all use ah?
