Singtel hi! Discussion Thread
maumu
Please refer to this thread -- post #4
⚡️💻 README First! How to Select Low Cost SIM Only Plans in Singapore? ✨
https://forums.hardwarezone.com.sg/...low-cost-sim-only-plans-in-singapore.7167328/
https://www.singtel.com/personal/products-services/mobile/eform/simonlyplusform
12-month contract
250GB of 5G+ data
FREE 6GB DataRoam Monthly to Malaysia for next 12 months (worth $192) --> Upgraded to 50GB as on 30-August-2025
1,000 mins
500 SMS
12 FREE months of Caller ID
12 FREE months of 5G+ Access
$15.28/mth
The plan is only for existing Singtel mobile customers, not for new sign-up or port-in. If you are keen, port to Singtel Mobile SIM Only 5G+ Enhanced Core for one month at S$40 and then recontract to this S$15.28 plan. That is based on the reports in the Singtel SIM Only thread.
thanks for sharing this. if my SH S plan (5G) turns out to be sh*tty, I may consider doing this... for peace of mind.
just wondering why "12 FREE months of 5G+ Access" when it already comes with "250GB of 5G+ data"? Is it a 4G plan in disguise where the 5G+ is an add-on feature? So it might be reverted back to 4G after 12 months?
been using heya (now hi!) and it's gonna be changed to Zym.
I see. You can try out Zym to see how it goes. I tend to think Singtel 5G MVNOs' 5G plans at around S$15 will be your best bet for Fibre Broadband replacement, if the data provided is enough for your use case.
Take note Singtel (same for M1/Starhub) 5G speed can be quite a bit faster than 4G, so you may need to monitor your data usage.
maumu
Zym (4G with free 180 days 5G+) has 300 GB local data per month... more than enough for me 😅
gapboy
I find ST mvnos are getting generous by the months due to competitions .. good for us as consumer
Read HWZ Forum Rules!
Please refer to the terms and conditions. Basically the expectation is that you will either recontract to this plan or port out. You do not want to keep this plan out of contract after 12 months -- it becomes very expensive.
https://cdn1.singteldigital.com/con...greements/eform/simonlyplusform_tncs_2025.pdf
SIM Only 250GB at $15.28: Customers must subscribe to a SIM Only Plan that is bundled with 40GB local data with a 12-month minimum subscription. They will be given additional free 210GB with 1000 local minutes talk time and 500 local SMS for 12 months. Monthly subscription will be chargeable at $15.28 for the first 12 months and $30.56 thereafter. Free data will be reflected in MySingtel app/ My Account portal within 2 billing cycles.
Free Caller ID for 12 months: Eligible customers will enjoy free Caller ID service for the first 12 months. From 13th month onwards, the Caller ID service will be chargeable at $5.45/mth.
Free 12 months 5G access for SIM Only Plus 30: Eligible customers will be able to enjoy 5G access (U.P. $5.09/month) free for the first 12 months, and $5.09/month from the 13th month onwards.
maumu
okay, got it. thanks for the tips...
maumu
300 GB sounds very little for Fibre broadband replacement...
But if your use case is okay, then just go ahead.
I'm a one-person household... when I was on heya 4G home network, I barely used 100GB a month.
no netflix, no pak game. no streaming videos. my desktop is more for doing work and stuff :o
I see, for one person, 300GB is enough.
We have five members at home (4 of us plus one helper) and it is roughly 1TB per month during school holidays and quite a bit less during school days, judging from the data from my two OpenWRT routers.
addict951
High Honorary Member
(This post was copied from Heya thread.)
eh guys I also wor.
There are no more $10 plans right?
But I see on shopee still can top up $10 to wallet.
Still can right? Anybuttie tried?
(the intention here is to deplete wallet balance)
then hor, say I top up $10, my wallet balance ish $16.9 liao. Then on renewal day I go to app select the 30-day $12 plan.
Then my wallet balance becomes $4.9 after renewal.
Y’all get what I mean? Every cycle use Shopee reseller to top up $10 then every 30 days deplete that wallet balance by $2 till left wif $1.9 residual eventually then 再来打算看怎么样 :look:
跟大家 share 一下
My method works hor - to expend the residual balance in your wallet
my wallet got $5.XX
I bot $10 via Shopee reseller to top up to wallet
After renewal (-$12), my wallet now ish $3.Xx
@keenklee
@xiaofan Where you get this esim adaptor ar??
breadie01
Did anyone manage to change an existing Singtel postpaid plan to the Hi! Senior or other Hi! postpaid plans?
Abit confused by the website.
Can I transfer my existing number to Singtel hi!
Yes. To transfer your existing number, it must be an active non-Singtel hi!* mobile line with no outstanding payments and registered under your NRIC/FIN with your telco. Your request to port-out from your existing telco must be submitted at least 7 days before your next billing cycle.
But in the terms and condition, it says non-Singtel postpaid.
i. “Port-In Service” means a service provided by Singtel Mobile which allows a Customer to retain his non-Singtel Mobile postpaid mobile number by porting his line from his current mobile service provider (“Donor”) to a Singtel Mobile postpaid line. Customer consents to the release of Customer’s information to a third-party central number port service provider and/or the Donor for the purpose of activating the Port-In Service.
You may want to contact Singtel for help to confirm.
But I believe the terms and conditions are correct, as it is also consistent with the FAQ.
https://cdn1.singteldigital.com/con...ts-services/mobile/hi/pdf/singtel-hi-faqs.pdf
3. Can I transfer my existing number to Singtel hi!?
Yes. To transfer your existing number, it must be an active non-Singtel mobile line with no outstanding
BTW, Singtel hi! 4G postplans are very similar to Singtel heya, afterall it replaces Singtel heya.
FAQ of heya:
https://www.heya.sg/faq
Can I transfer my existing number to heya?
Yes. To transfer your existing number, it must be an active Postpaid mobile line with no outstanding payments and registered under your NRIC/FIN with your telco.
We are unable to support port-ins from Singtel plans at the moment.
SingTel Facebook Ads.
No real promotion for the SingTel hi! Postpaid 4G plans. But the senior plan can be a good competitor for S$5 SIMBA Senior Plan and S$5 eight 4G Senior Plan, especially for local usage.
Experience the hi! Life on Singapore’s best network.
Enjoy fast activation, reliable speeds and great value.
💥 $12 hi! Plan — 400GB for $10/month ($2 online discounts for 12 months when you switch!)
💥 $5 Senior hi! Plan — 400GB
All plans come with roaming data, local calls and SMS included.
Activate instantly with eSIM:
www.singtel.com/hi
Or visit a hi! Retailer near you:
www.singtel.com/hiretailers
#Singtelhi! #hiLife #HelloPossibilities
IMHO.
I had just let 3x Heya lapsed by not buying a plan. :ROFLMAO:
Welcome done Singtel.
Haha, you really like heya so that you have four heya lines.
After the migration you only keep one Singtel hi! 4G postpaid line.
To me both heya and Singtel hi! S$12/S$10 plans may not be popular.
SingTel MVNOs' 4G plans around S$10 makes more sense with 180 days free 5G trial.
Or go with SingTel MVNOs' 4G plans at around S$7 since they are cheaper.
Only the S$5 hi! senior plan may be attractive if the users have concerns about the quality of eight S$5 4G senior plan (eight 4G is quite congested) and SIMBA S$5 senior plan (SIMBA coverage and speed are not great).
But for those who like Singtel brand, then Singtel hi! 4G S$12/S$10 PostPaid plans may still make sense if comparing to Gomo 4G saver plan at S$10.18 per month (100 GB local data, 2GB MITTA roaming data) and Gomo 4G Pro plan at S$15 per month (300 GB, 6GB MITTA roaming data).
MITTA: Malaysia, Indonesia, Thailand, Taiwan & Australia
But Gomo has 5G plans.
https://www.gomo.sg/
BTW, I do not think Singtel hi! 4G and Gomo 4G plans will have higher priorities than SingTel MVNOs' 4G plans, most likely they are of the same priority. Therefore I feel SingTel MVNOs 4G plans are more worth, especially the plans at around S$10 yet with 180 days 5G access.
